Question about IBM ThinkPad 380ED
380ed 2635-6au put a new battery the little round ones and now when i start it it does nothing but say bad command mscdex 2.23
  • 2,028 Answers
This file/command, mscdex 2.23, is the MS-DOS CD-ROM extensions file. If this has glitched or is corrupted it generally won't stop the computer from running, but it will stop it from reading CD's or newer CD's. The first link bellow is the history and the download for the mscdex, but the machine will need to be up and running in order to download it. If you can't get the machine running, try to reinstall the operating system.You may need to flash the bios if it won't let you install the new system or read from the disc. The second link bellow is for the most recent bios flash for your machine. To flash the bios you will need to make a bootable floppy, using a different computer (obviously). The third link is for a updated CD-ROM driver from IBM, that may do the same as the mscdex, and the fourth link is to the driver list for the 380ed at IBM's support site. You might browse over them and find some updated drivers or patches you need.;EN-US;q123408
Posted on Jul 30, 2008
Replace bios battery 161 and 163 error codes
Most computers have a 'keep-alive' coin-cell battery on the motherboard that provides a DC voltage to keep the bios memory contents preserved when the computer is turned off. After a couple of years, the batteries need to be replaced with new ones. Look online for the service manual for your Thinkpad or look up 'Thinkpad 380ED bios battery replacement' on your favorite search engine to see if you want to tackle the process yourself.
Jul 24, 2014 | IBM ThinkPad 380ED
Alarm wont set 2008 jeep commander
the car came with 2 RKE FOBs
are both dead.?
alway have 3 FOB if not you can not reprogram a new one. self.
can cost you $300 for more to tow your car to the dealer if the 1 fob dies. never run one fob. or bad happens.
put in a new battery in the FOB for door issues
the transponder part does not use the battery .
the transponder must be good, or the car would never run.
the jeep cuts fuel after 2 seconds if the transponder fails.
Apr 20, 2014 | 2008 Jeep Commander Sport
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
Cam corder will not turn on,I have put in a new batteryt(the little round one,a little bigger than a dime)and have it hooked up to 110 volt.Still nothing.The battery I took out was a DL 2025 and the one I...
That isn't the problem. Those batteries are equivalent. These little coin cells are only used to back up the settings memory and the clock. Your problem seems to lie with the main source of power. I don't know if your camera will work on the mains adapter alone without the big battery.
Nov 25, 2010 | Sony Handycam CCD-TR44 Camcorder
IBM Thinkpad 380ED shows battery at 100% but will not run on battery
Hi, Unfortunalty this is an hardware failure there is nothing you can do. If you are under warranty i suggest you to contact the reseller/manufacturer to get a replacement units, it should be no problem at all this is a common issue on batteries. Thanks and have a nice day J -
Feb 20, 2010 | IBM ThinkPad 380ED
Wondering where and what to type in autoexebat
Those are old DOS commands, and depending on the OS version, is located in c:\windows\dos.
mscdex.exe is the driver that should be listed in config.sys.
like, DEVICE=C\windows\dos\mscdex.exe
When running Windows, the driver is re-loaded under it's own section, so the CD drive may be bad or the interface on the motherboard - if it shares the cable to the hard drive, then the interface is OK.
Sep 22, 2009 | Soyo SY-5SSM Motherboard
380ed 2635-6au
Just notice I answered this one already. Check your other post for the solution.
Jul 30, 2008 | IBM ThinkPad 380ED
I have a laptop ibm 380ed
you will need to use a password reset tool such as Winternals ERD commander to reset the password. the only other option is to reload the operating system. it is important to use a password that you will remember or write it down. BPCS
Jan 31, 2008 | IBM ThinkPad 380ED
161 and 163 errors
as soon as i turn on the laptop it sez ERROR 161 163
Jan 13, 2008 | IBM ThinkPad 380ED
IBM ThinkPad 380ED Logo
80 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
