Question about Toshiba Televison & Video
I have a toshiba dvd player that reads locked on the screen and wont open up to eject the disk
    Master:
  • 623 Answers
Enter code to unlock
Posted on Jul 30, 2008
How to Unlock a Sony DVD player DVP SR320 which displays "LOCKED" when eject/open button is pressed?
Apr 22, 2012 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
DVD tray will not open. Lock is not on. I have tried unplugging the unit then plugging it in again. What do you suggest?
I think your DVD player is trying to read the disk, but it can't. Try unplugging the unit. Holding down the eject button and plugging it back in. After it begins to to power up you can release the eject button. What your wanting to do is to get it to eject before it tries to read the disk. Good luck.
Apr 20, 2010 | GoVideo DVD Recorder/VCR with YesDVD
The dvd slot wont open. the last disk that i put in it still plays fine but i cant open it to put a new disk in.
Hello there:
normally go to my computer and look for your player and click on eject,
but if this doesent work get a small paperclip and on the dvd player look for a small hole and insert it and press firmly and this will open the drive door ok. this should help you out ok?
best regards mike.
Aug 25, 2009 | Toshiba Televison & Video
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Apr 12, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Upon trying to remove a disk, disk remains in player and tray opens empty
This is caused be the "lift" part of the mechanism not functioning properly. A fix may be inexpensive or not, depending upon what is needed to make it rise and lower properly....accordianman
Mar 29, 2008 | Toshiba SD-3980 DVD Player
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Televison & Video Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
