Means no water getting to machine or pressure switch not tripped. Check all water valves are switched on and there is water. If the machine is filling up then flashing FH then it is most likely your pressure switch that is faulty. If there is no water at all then its most likely you water inlet valve. Both of these are easily changed by removing the top panel. The pressure switch is a round part about 2-3 inches and has a thin tube pushed onto it and a wiring plug. The valve is at the top back, most likely if there is 2 hoses then it will be the hot water 1. Hope this helps
