Question about E-Machines E17T 17" Flat Panel LCD Monitor
E machine 15" lcd pc monitor
I have recently purchased a second hand monitor e machine 15" for a pc but there was no power cable with it i have not seen this before but
the only way it seems to plug in is in the plug that you put in the pc for the pc video card can you please tell me what i need to buy for this.
many thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Here is user guide link.
I think this may help you
Posted on Jul 30, 2008
Never light up on screen when turn it on
On any Panasonic Toughbook, if the LCD does not "Light-Up", I would try the following:
Step 1: Make sure the Toughbook is Powered Off.
Step 2: Hook-up and external LCD Monitor to the VGA Port.
(On the CF51 with the ports facing you, the VGA Port is the third connector "color blue" from the right hand side).
Step 3: Power On the external LCD Monitor.
Step 4: Power on the Toughbook.
If the external monitor works then purchase a second hand external monitor. A used 17" LCD monitor should cost $20 or less and the VGA cable (used) should cost $5 or less.
This also means that your LCD may be burnt out. If this was a CF53 or even a CF52 then it is worthwhile to repair. The CF51 in my opinion is too old but at least you can continue to use it with an external monitor hooked-up.
That is it. Good Luck and Best Regards from:
Richard Montreal Based Panasonic Canada Authized ToughBook Dealer since 1989
Feb 18, 2014 | Panasonic Toughbook CF-51 Notebook
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3. Unplug power cable from LCD, Once power cable is unplugged from LCD, press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
Oct 06, 2008 | Samtron Computers & Internet
I purchased a 3M 15"
This display uses a capacitive touchscreen. It relies on the conductivity of your finder work. It may be that it has lost sensitivity and only works when there is a path to ground through your body. If this is the case then the touchscreen will need replacing.
Feb 18, 2011 | 3M 11-4922-129-00 (Black) 15 in. Flat...
I bought 2nd hand Apple Studio 15" monitor without power supply- where can I find one not over £50? Is there a generic supply I could use or is it locked down to apple supplies, which are thin...
Anytime I purchase second hand devices, especially Apple, I go on Ebay.com. It sounds like you're in the UK so you may want to search on Ebay.uk to keep shipping costs down. Just type in your model. I purchase quite a few Apple products and the particular power supply you're searching for should be under 15 pounds UK.
Feb 08, 2010 | Apple Studio (Metallic Silver) 15" LCD...
Monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Nov 05, 2008 | Philips 170B4MG 17" LCD Monitor
Iiyama vision master pro 450. Faulty auto switching??
hi,the problem is with the LCD electronics , you will need to get it repaired from the sevice center, when u power up the LCD its heating up something inside which is switching it off .
Dec 22, 2007 | iiyama AX3815U 15" LCD Monitor
Dell e171fp + turn off after a second
hi, are you able to browse thru the LCD menu, there must be some settings for power management.. let me know?
bye
Dec 15, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Dropped lcd monitor
Very often the problem is that when an LCD monitor is dropped, the ribbon cable and power cables which have very little slack become partially unconnected from the ports they plug into. Unplug the monitor, remove the back casing, and have a look to make sure the ribbon and power cables are seated properly. If in doubt, reseat them by hand.
Good luck...
Nov 14, 2007 | Computers & Internet
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
E-Machines E17T 17" Flat Panel LCD Monitor Logo
83 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
