Question about Microsoft Windows 2000 Professional for PC
Erase an actualizations
I erased some actualizations of windows and now i cant open files who have images or photos, it appears a message that say KodakImg.exe cudnt find the point of entrance......... it can not find the point of entrance of the procedure ?IsICMEnabled@@YGHXZ on the library of dynamic links imgcmn.dll
    Scholar:
  • 69 Answers
You could reinstall the Kodak software or download another photo viewer and install it. You need to make sure the photo viewer will allow you to open with straight through double clicking. Most do.
If u want a simple photo viewer that supports only a few images like JPG
www.fastpictureviewer.com
Posted on Oct 15, 2008
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
The message 'Naming error' has appeared on the screen and is preventing me taking any photos. Canon S51S
From page 156 of the "Advanced Camera User Guide":
The file name could not be created because there is an image with the same name as the folder that the camera is attempting to create, or the highest possible file number has already been reached. In the Set up menu, set [File Numbering] to [Auto Reset]; alternatively, save all the images you with to retain onto a computer, then reformat the memory card. Please note that formatting will erase all the existing images and other data.
May 19, 2011 | Canon PowerShot S51S Digital Camera
I took some photos that appeared in negative. please show me how i can repair those photos. thanks
Many image viewing/editing programs will let you change between negative and positive images, but the simplest thing in Microsoft windows is to just use the built in Paint program. Open the image and select "Invert Colors" from the "Image" menu. You may want to save it out with a different name so you don't erase the original.
Feb 27, 2011 | Samsung S760 Digital Camera
Cannot delete read only audio file from cd
You cannot delete a file from a CD-R or CD+R which is why it is a read only file. If you left the session open when you wrote to the disk you can add files to the CD. If you closed the session with your burning software it will fill the disk with blanks not allowing you to write any more files to the CD. You can Erase and Write to a CD-RW, but you will have to erase the entire disk and rewrite to it. You can copy the files to your hard drive and insert a new disk or erase the CD-RW and reburn the files excluding the one you do not want on the CD. Bottom line the CD has optical information physically burned on the CD unlike magnetic media it cannot be erased by rearranging the metal oxide making the file unreadable. Magnetic media works similar to an Etch-a-sketch where you can easily erase the image by shaking it. CD's and DVD's work like a canvas where you can paint easily, but you have to paint over the image or strip the paint to delete the image.
Apr 06, 2010 | Microsoft Windows XP Home Edition
External wont open on mac
if you have used the hard drive on a windows pc some format types cannot be recognized by mac
follow these steps to make it usable by mac and windows
*THIS WILL DELETE ALL FILES ON THE EXTERNAL HARD DRIVE AND DOE NOT ALWAYS WORK
Go to Finder -> Application -> Utilities
Double click for Disk Utility
Select the external Hard Disk you wish to format at the left column
Click on the Erase tab
At the “Volume Format” select “MS-DOS File System”
If you confirm to format your hard disk for mac and windows, Click on “Erase” button.
Pop up window will ask to verify the erase procedure. Click the erase button again in the window to start the erase process.
Once the erase process finish, your external hard disk may be able to use in Mac and Windows.
Mar 20, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
All my pictures erased from the card without using the erase function . When I tried to look at my pictures, the message no images appeared.
You may have erased the photos by mistake. Try reading the memory card with your pc using a usb card reader to see if the images are possibly still there. Or you can go to this link (below) and use the free trial software to recover your photos.
http://www.datarescue.com/photorescue/v3/index.htm
Good Luck,
Eric
Jul 09, 2009 | Canon PowerShot A520 Digital Camera
Deleteing txt messages on a LG enV2
Hi, try this
Using the Internal Keypad 1. Open the flip and press[MENU]. 2. Press Messaging. 3. Press the Right Soft Key [Options]. l Press Erase Inbox to erase All (read and unread) Messages or Only read Messages in the Inbox. l Press Erase Sent to erase all unlocked messages stored in the Sent folder. l Press Erase Drafts to erase all unlocked messages stored in the Drafts folder. l Press Erase All to erase all messages from the Inbox, Sent, and Drafts folders (except locked messages). You can choose whether or not unread messages will be erased. 4. Select Yes to erase the messages selected. A confirmation message is displayed.
Mar 24, 2009 | Cell Phones
Erase memory to recieve image messaging
Please move your Photos, contacts messages, and applications from Phone Memory to Memory Card.
then your issue would resolve. you can do this by file manager.
Feb 17, 2009 | Samsung UpStage SPH-m620 Cellular Phone
When I paint on a image it does nothing but history says all.
Maybe you did in the wrong layer.
Open the layer window, then select the layer with the image you want to erase/ paint.
May 19, 2008 | Adobe Photoshop CS2 for PC
Microsoft Windows 2000 Professional for PC Logo
163 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
