Question about HP Office Equipment & Supplies
I want to install my Hp officejet 7300 series all-in-one to a new CPU
    Genius:
  • 1,056 Answers
Ok, connect the printer to the computer, put in paper and the toner, turn the printer on, and if your computer is Windows, click START>SETTINGS>PRINTERS AND FAXES>ADD PRINTER
Go through the wizards to install the printer.
Or if you have the HP install disk, hook up and power on the printer, put the install disk in, and go through the install routine.
Posted on Jul 30, 2008
Hp officejet 7310 all-in-one printer wireless connection
reset the printer .
and start over in the manual.
no PC stated,
no statement of what works and what dont ,togethe
do you have a router, ? if yes is it theres or yours?
seems call them get teh unstated laptop working first.
first with ethernet cable, that must work first.
ask them , if its their router and their modem.
if all that is yours, your hardware, then you need to tell what it is
first to get connected. make and model..
i guess you now have cable modem.
to get the router working it needs to be setup to the new cablem modem turning off all DSL modes, and using direct mode.
the printer is here.
for any setups , and resets , are all there. to read.
https://support.hp.com/us-en/product/HP-Officejet-7300-All-in-One-Printer-series/391181/model/391183
Sep 30, 2017 | HP Officejet 7310 All-In-One Printer
I lost software for my scanner one touch 7300 usb i need to reinsall it on my pc wadejohnathan7@gmail.com
i have error hp officejet 5610 all-in-one printer :- scanning software could not found, or your scanner is not connected. please make sure scanner and software are properly installed.
Sep 26, 2010 | Visioneer OneTouch 7300 Flatbed Scanner
I had to re-install the software and now the scanner will not work?
Delete it and install it again .. I have to reinstall my 7300 (series) printer about once every 6 weeks. I keep the CD handy. My trouble is with the print function ... the printer likes to be "off line". Make sure you update your driver through www.hp.com/support.
I hope this suggestion helps you
Aug 16, 2010 | HP OfficeJet 7310 All-In-One InkJet...
We are having problems with our Office Jet 7310, for example when we print a document on every other line the bottom of the g's are cut off and the rest of the characters on the line are faded at the...
To determine what the problem is run a self test page. Push the "Setup" button then choose option 2 then option 5. This will print a Self test report page.
For more detailed information (assuming you did a standard install) go to "Start", choose "All Programs", choose your HP menu option, choose "OfficeJet All-In-One 7300 series", choose "Help". Once your in Help scroll down to "Maintain your HP All-In-One", open the sub-menu and choose "Clean the HP All-In-One". On the main help page sellect "Print a Self-test Report". This should tell you just about all you need. Good Luck!
May 31, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I am trying to install my printer hp psc 1200 hp officejet 4100 series all in on to my new compt. Vista. It won't work
Hi.
for Installation u need Printer drivers for win vista
please use below link if u want Drivers For vista OS
Hp psc1200 series
Hp Officejet 4100 series
in officejet series please select proper model witch u have
if this information is useful for u please Rate me.........
Jul 11, 2008 | HP Office Equipment & Supplies
We have the HP Officejet printer 7300/7400 series. The CD version 4.70 does not seem compatible with our new laptop which has been loaded with the Windows XP vista. We need an updated CD.
Dear alexzb,
you can download the updated driver for your officejet from this site:
http://www.planetamd64.com/index.php?showtopic=6711&st=0
Regards
Jul 03, 2008 | HP Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
48 people viewed this question
Ben Johnson
