Question about Panasonic CQ-VD7001U Car DVD Player
Ebrake safety feature
How can i bypass the ebrake safety feature?
  • 1,586 Answers
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 01, 2008
Bypass ebrake to a panasonic cq-vd7005u
Why would you even consider doing this??????????
Apr 11, 2013 | Panasonic CQ-VD7005U Car DVD Player
How do i bypass the parking brake feature on my jensen vm9324
Bypassing the EBrake wire is not a good idea. Should you have an accident as a result of watching moving video in the view of the driver (illegal in ALL 50 states) your insurance company will NOT pay the claim. God forbid there is a fatality, then you are going to be charged with Manslaughter as a result of inproper equipment. Best bet is to connect the PINK wire to the vehicle's parking brake.
Mar 07, 2012 | Jensen Car Audio & Video
My remote wont work on my jensen uv10 and i want to bypass the parking brake. Can you tell my how to do it without remote. Thanks
You don't need the remote to bypass the ebrake withe remote use a tago switch to bypass the ebrake hook it up to the pink wire on back of the deck.
May 04, 2011 | Car Audio & Video
ENABLE TO PLAY MOVIES , I JUST GET SOUND O MY PIONNER DVD PLAYER
you need to do a safety bypass to the ebrake sensing wire (this is a safety feature to prevent accidents) Remove the wire fromt he Remote slot(blue wire) and put it in the blank hole in the plug provided with your stereo... now ground the wire you have now bypassed the safety protocal and enabled video while moving a google search for pioneet avic bypass will yeild vidoes or a youtube search for a video tutorial
Feb 27, 2011 | Pioneer AVIC-D3 Car DVD Player
Need bypass factory alarm in 99 dodge
well thats an interesting idea but by bypassing the alarm your car will not usualy start it is a safety feature that is built in to all chrysler autos it will disable the starter coil door locks windows and half the electrical systm as a safety feature and anti theft feature
Dec 30, 2009 | 1998 Dodge Caravan
My pioneer indash avic d3 wont play dvd's you
this until has a safety feature installed that will not let you view video while in motion. it has a light green wire on the back that is supposed to be connected to the cars ebrake wire so that in order to view video you would have to have your ebrake ingaged. it also allows you to be able to type in address for the navigation. if this wire is not connect or not connected properly, you will get a messages that says drive can not view video will driving..
double check the connection....or you can just bypass it completely. i have attach a link on how you bypass this feature which will allow you to watch video and type in nav address while drivin
http://avic411.com/forum/viewtopic.php?f=11&t=7998
Aug 15, 2009 | Pioneer AVIC-D3 Car DVD Player
Child safety feature is worn out and won't let my machine run. How do I bypass/disable this feature so my machine can work again?
YES. You can bypass this feature pretty easily. There are two wires going to this little device. Pull the two wires off and use a wire nut to "wire" them together.
Be sure to unplug the dryer as you do this work so you don't get a serious shock.
May 20, 2009 | Washing Machines
Cant play the dvd player
You need to solder the back pins on the unit. We can do it at www.turbotunes.com
-Steve
Apr 09, 2009 | Pioneer AVIC-N2 Car DVD Player
Bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Mar 24, 2009 | Pioneer AVH-P4900 Car Video Player
AVH-P4900 E-Brake ByPass?
my name is derrick and i found out how to bypass the e brake using a relay if you need help email me at derrick_bow@hotmail.com and no you don't need a switch.
Nov 15, 2007 | Pioneer AVH-P4900 Car Video Player
Panasonic CQ-VD7001U Car DVD Player Logo
219 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
