Question about Linksys (NH1005) 5x10/100 Mbps Networking Hub
Help me my hub has been working fine for about 6 months and now all of a sudden when i plug in more than one ethernet cable all of the lights start to flash and there is no connection to my xbox 360 or computer
  • aj25374 Jul 31, 2008
    thank you i was starting to figure that it was broke or something but i wanted another opinion before i went out and bought a new one this time i wont go to walmart haha
    Genius:
  • 1,056 Answers
It sounds like the hub has died.
This is not an uncommon problem.
From the symptoms you have described, I would suggest replacing the hub.
Trying to fix them is like trying to refill a Bic lighter.
Posted on Jul 30, 2008
  • Coss Jul 31, 2008
    5 port hubs are inexpensive (under $30)
    You might want to try a different brand.
    I use Netgear, and have never had any major issues with them.
Computer in wall network wire stopped working after 6 years.
I would use a spare hub or switch in place of the existing hub. This sounds like a failing hub or switch to me. Two cables would not normally go bad at once.
May 25, 2015 | Computers & Internet
I am trying to set up a switch between my PS3 and my PC. I have an external DSL modem. I purchased a 5 port switch(Rosewill RC405-x) but no luck. Can I use an ethernet splitter instead?
You did not explainhaow you connected all your equipment together.
Connect your PC and PS3 into the 5 port switch.
Connect your DSL modem into the 5 port switch, if there is a WAN/internet port on the 5 port switch then connect the DSL model into this port.
You may need to power off the 5 port switch wait a 1 min and power up the 5 port switch again so it can setup an IP address table for the connected ports.
If this still does not work the replace the 5 port switch with a normal 5 port hub.
Mar 20, 2012 | Rosewill RC-405 - Switch - 5 ports -...
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
I re-imaged the unit & it says the network card is working properly in device mgr. But it wont go online when i connect a cable. It stays on "Network Cable Unplugged". The LED on the connection on the...
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
Sep 29, 2009 | HP Pavilion N5415 Notebook
STP cables - with - Linksys Ethernet 5-Port Workgroup Hub
Most liklely you shouldn't do this unelss you are willing to do the work to properly ground the cables on each end. I'm pretty sure your hub iuses a DC power brick so it won't handle it for youm you'll have to build a breakout box of some sort to do this. Remember that if the cable isn't grounded properly on each end it will actually make things worse.
Running at 10M with Cat 6 cable it is highly unlikely that you will have issues with electrical interferecne even with the the undesirable routing of the cables in your house.
Aug 21, 2009 | Computers & Internet
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
HOOKING UP A HUB WITH MODEM
plug the cable to one of the ports on the hub which I'm sure you tried... if not, there should be a port marked with an "X" which means it's a cross over port which might do the trick. Just make sure the port next to that port is free (not plugged to anything).
Do you get any lights when you plug an ethernet cable between the router and the hub?
Jun 15, 2008 | Computers & Internet
Not able to connect to the internet
Please list the model of the network hub you are using.  Also is a "hub/switch" or a routher.  Also are you using a DSL or Cable internet connection?  Please provide a little more details.
Oct 26, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
Linksys (NH1005) 5x10/100 Mbps Networking Hub Logo
162 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
