Question about Sony Playstation 3 (PS3) Console
HDMi I have connected my PS3 first with the component cables and the stereo audio cables. The problem started when i connect the HDMI cables and the system identified the cable. I hit the button to continue and the next second the screen was dark. Please! tell me how to fix it? SPC Rosario, Okinawa, JP
  • 4 Answers
Make sure your screen has HDCP Support alsomake sure your tv is in hdmi mode.
Posted on Jul 30, 2008
Hdmi ports 1and 2 are disabled what can i use in place of hdmi to make it work
A PS3 Component cable would be the next best option if the TV has Component connections
Jul 09, 2014 | Sony Playstation 3 (PS3) Console
I need to connect a console to a Sansum LED TV
You need to fino a cable to connect to it, most new Blu-Rays have what is called HDMI, this is also found on newer Xbox 360 and all PS3, whan it says HDMI, the best thing is to get an HDMI cable (don't pay more than $10) and plugging into it and the TV. There you have all of what you need. If the console does not have an HDMI, you need to look for an specific A/V cable that connects to the TV, it may also be a component cable, in any case, you need to connect each cable to an specific port of a color, the white and red (last 2) represent audio (left and right) and will output stereo audio. If something can't be seen when using HDMI, you will need to use A/V to lower the Definition to 480i then slowly raise the definition to 720p then 1080i
Oct 27, 2011 | Nintendo Wii Console
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
How do I connect my Sony PS3 with HDMI and component sound with Kenwood VR-606
Component outputs do not provide sound. Component CABLES however can be used as a rather equal alternative to analog cables for audio.
Your receiver does not have connections for component, nor HDMI. You can however still connect your PS3 to it for audio by any one of its three digital inputs. It only has S-video and does not upconvert video signals so I recommend against making any video connections to it. Connect the PS3 video directly to your television for whichever video input it is compatible with High definition video. This method will always provide the best picture.
Dec 12, 2009 | Kenwood VR-606 Receiver
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
I want to connect my ps3 via hdmi cable to my magnavox 51mp392h/17 hdtv but theres no hdmi jack on my tv what to i do?
If there is NO HDMI on the TV, There are 2 options to still get HD. 1. Check if your TV has a DVI input, If it does you need a DVI to HDMI converter. This can be a problem with some TV models it might not sync up 100%. 2. I recommend doing this, Purchase the Component Cable For the PS3 from Best Buy or any Game store. Make sure it is the ONE for the PS3!!!!!!!!!!!!!! This cable will give you up to 1080i resolution and stereo Audio. Plug in the Red, Green and Blue into the Component (R,G,B) Input in the TV, The Red and White (audio) will follow into the same Input (White and Red) just match the colors from the cable to the TV. On the PS3 in the Menu go to the 2nd row from the Left and down to DISPLAY SETTINGS. Select Component (under HDMI) check off everything except 1080p and then SAVE by pressing X. If you have a Receiver (AMP) that your Audio goes into, Then you can buy an Optical Cable for Surround Sound. Plug in the Optical cable then on the PS3 go into the menu, 2nd row, Sound Settings, Choose Optical, Then choose Auto and SAVE! Hope this will Help!
May 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
