Question about Motorola Mobility HS850 Consumer Headset
How to pair a motorola hs8501226b to an i phone
  • 356 Answers
Turn on BT on the iPhone. From the home screen: Settings > General > Bluetooth. Setup the headset to be discoverable (push and hold the button on the HS700 until the ring turns blue. Extend the boom mic. I believe you do the same on the HS850.) iPhone finds the headset. Enter the code for the headset. Mine was 0000. I believe that's universal for Motorola BT headsets
Hope this was helpful
Positive Feedback ALWAYS Appreciated :)
Posted on Mar 04, 2011
SOURCE:
Motorola phone will not connect with Motorola roadster
Sorry you are having an issue connecting your Roadster to your phone. It is best if you fully charge your roadster. Then turn off or delete the pairing the roadster shares with any other device. If no other device is connected when you turn on the roadster it should report that it is ready to pair. On your phone turn on Bluetooth and search for the roadster. When it is found select it on your phone to initiate the pairing process. If it asks for a code enter the code 0000 on your phone to confirm the pairing.
Mark
Motorola Support
Oct 11, 2014 | Motorola Cell Phones
Bluetooth pairs but will not connect
Try pairing and connecting with another headset. Or delete the pairing and pair again.
Mark
Motorola Support
Aug 21, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
How can I pair the Motorola H550 to a second phone?
Did you mean an HX550? HX550 Pair connect with your phone . the H550 cannot be paired to more than one device.
Mark
Motorola Support
May 22, 2014 | Motorola Mobility H550 - Bluetooth Headset...
Motorola h730 after factory reset will not stay paired after closing and opening again
Delete the pairing on the phone and then re-pair. Also ensure your headset is fully charged. It should autopair with your phone after a reset when you open boom if phone has bluetooth turned on and is in range.
Mark
Motorola Support
Feb 10, 2014 | Motorola Mobility H730 Bluetooth Headset
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
How to pair my Motorola H500 headset with my HTC Touch
i have a pre paid phone from net 10..the phone is a motorola..how do i get my head set pairing mode and get my phone to detect it..i have no pin for the ear peice ..
Aug 02, 2008 | Motorola Mobility H500 Wireless Headset
Pair with mobile phone
when you activate the Jabra put your mobile to search for the bluetooth device when it finds it then pair code is 0000....then it should be paired
Mar 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola HS500 Headset
I had the bluetooth paired with my red motorola raza, I just brought the grey motorola raza and I cannot get the bluetooth to pair with my new phone. It's the same exact phone, just a different color. The bluetooth is fairly new. Now the bluetooth wont come on at all since I tried to pair it with the new phone.
Dec 29, 2007 | Motorola Mobility HS500 Wireless Headset
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility HS850 Consumer Headset Logo
56 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
