Question about Kitchen Ranges
Frigidare Model MEF352BFWA Electric Range
The control panel light for the buners would not come on so the burners won't come on, so I pulled the plug waited and plugged back in and it the burners and oven worked for just a little while, then they would not come on again even if I pulled the power cord,,,,,what is the problem, is it worth fixing?
  • 1 more comment
  • Dewayne Johnson Jul 30, 2008
    I checked there are no fuses on the control panel,also checked the manual so thats no the solution
    checked manual no fuses listed for control panel
    The red panel lights come on but won't heat burners or the oven...must be getting power to it something in the panel?
  • 3,037 Answers
Sounds like the control panel is going and needs to be replaced. Check for any thermal fuses and replace them first (usually located inside the back panel) Otherwise, the control panel will need to be replaced.
Let me know if you have any further questions
Posted on Jul 30, 2008
    Genius:
  • 2,035 Answers
Please try to plug the unit in different power unit if the problem occurs then its problem with oven ..
Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Yes. first just check for any burned fuses on the control panel area..
let me know
My burners won`t click to light
What is the complete model number of the unit?
Dec 15, 2012 | GE Profile 30" Slide-In Gas Range -...
The heat control on one of my burners on my smooth top range doesn't work correctly. The burner is only on when control is turned all the way up, lowering the control turns off burner
the burner; control/switch is bad /unplug range ..pull knob off burner control to see srews..remove back panel on range..1/4 inch srews are used ....look at all them wires an switches ..wow ..locate the bad switch ...buy a new switch from appliance parts store /or one from a used appliance store ..make sure you have the make /and model/serial # off of the range... to get the right switch ...install switch.. remove one wire at a time when installing switch or wright down how it is wired ...let me know ..good luck/joe/
Aug 26, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I have kenmore electric stove. the two large element dosen't work
try the controlls or switching the elements with the other buners.
Jul 08, 2010 | Kenmore 99123 Electric Kitchen Range
None of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Maytag gemini gas range--3 burners wont light, they don't get the signal to light when you turn the burner on. They do light if you turn on one of the burners that work and one that doesn't at the same...
Hi, there is a switch on each burner control knob shaft. These switches wear out and are easy to replace once you remove the panel over the knob area. Each switch has 2 wires plugged into it and costs around 5 to 10 dollars. Any switch causes all burner electrodes to spark. Good luck,
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Frigidare range glgf376dsm display not working
That's common for the burners to work since they & ignightors have nothing to do with the control board. The oven light is also run by the control board. Before replacing the control board, make sure you have both phases of the power coming in. One 1/2 of the 220 operates the burners and the other phase is the power to the controller. The controller then put both phases on the heating elements. There should be a tech sheet and schematic on the back of the stove or under the hood where the controller is. Good luck
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
118 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
