Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Picture looks like it is in 3D
Hi there. I was looking for a solution and I saw your post "does the red look like its 3D or is it just blurry let me know I may be able to help you".
This is what happened to me. Just overnight, the picture went from perfect to this awful 3D movie! It looks like there is an arc of red causing a double picture. Is there anything that can be done...cheap?! Thanks!
Kathy
kg_springfield@yahoo.com
  • parkertx4 Dec 10, 2008
    I have the same problem. Was watching it last night and all was fine and then turned it on this morning and all the colors are out of adjustment. Any solutions?
  • mcqualude Dec 20, 2008
    Left for a few hours, came back and the red is all out of whack, off to the right.
  • Hitachi Master
  • 8,617 Answers
Yes you need to replace both convergence ICs. They are both STK392-150 you will also need to replace the 6 feed resistors. You will need ( two ) 1.8 ohm 1watt metal film resistors.
( one) 3.3 ohm 1watt, ( 0ne) 2.7 ohm 1watt, ( one) 4.7 ohm 1 watt, and ( one ) 2.2 ohm 1watt . The resistors are all 1 watt metal film resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures, plus free tech support.
http://servicemanuals.vstore.ca/
Posted on Aug 02, 2008
    Novelist:
  • 132 Answers
This TV has 110 and 150 IC, replace with originals and leave resistors alone unless they are damaged. Replace resistors with original values from manual if burnt. 110 and 150 are both designed for specific situations with specific resistors in the circuit.
Posted on Dec 06, 2008
Picture is blurry
Can you clarify "blurry", is the color skewed or even 3d looking? I am here to help and if you can post a photo here that would help---see attached photos of convergence problems which can fit the description you gave:
Dec 04, 2012 | Philips 50P8341 50" Rear Projection...
My rca hdtv has a 3d look, and it is blurry, what can i do
this 3d look is coused by bad convergance ics you have to replace them no adustment will fix this
Dec 24, 2007 | RCA HD52W59 HDTV Projection Television
Really blurry
Look in main menu for convergence and see if it will adjust--if off either adjustments or a bad chip---picture will look 3d and red or blue outlines around lettering etc.
Oct 22, 2012 | Toshiba 61H70 61" Rear Projection...
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
My picture is blurry, re-setting the convergance helps
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Our picture is very blurry with a red and green hue and shadowing. What can I do?
if it looks like 3d, you have a convergence problem---you may find it helpful to post the brand and model number
Aug 08, 2009 | Philips Televison & Video
My picture is like a 3d look. I can't adjust the
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ... thank u.........
Jun 03, 2009 | Philips Televison & Video
RCA R56WH78 picture quality is blurry/3D
rubber cap? i dont feel you have the correct fuse. fl231 is a small rectangular brown fuse next to flyback. I have written detail instructions on the replacement of this fuse. look under willtab profile under tips in tricks section. intitles the fl231 fuse problem. this also help you indetify if this is the problem.
Nov 22, 2008 | Televison & Video
Pictures looks 3D-ish with small horizontal lines
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
