Question about Dishwashers
WHIRLPOOL DISHWASHER ADP6000IX
ERROR 4 COMES UP AND DISHWASHER WILL NOT WORK
I have erroe 3 comes up and dishers not wash
Posted on May 21, 2013
Your not alone. i to have this error 4 and so do hundreds of others.it means low water level even like mine your water level probably isnt low.what happened to mine was the sensor got a layer of fat and oil scum buildup on it and couldnt detect the water level so i cleaned it and worked good for another month. then same problem.solution- dishwasher had an "accidental short due to water leak" wich insurance covered and bought me a new dishwasher (fisher and pikel) now no more problem
Posted on Aug 20, 2008
  • yesseppi Nov 16, 2010
    Error 4 is caused by an overfill after you have fixed the cause of the overfill you will need to tilt the dishwasher either forward or backwards with towels around the base to mop up any water that comes out of the base of the dishwasher. Once there is no more water coming out return the dishwasher to level and turn it on and you will have no more "error 4"!
3 Suggested Answers
jfarrell531
SOURCE: WHIRLPOOL DISHWASHER, ERROR CODE 4,
Well done Kazbarr worked a treat I am still waiting for Whirlpool to get back to me with an answer!!!
Posted on Mar 03, 2010
SOURCE: my dishwasher is coming up
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Posted on Aug 13, 2010
Model ADP6000WH/ADP6000IX. What is error 2?
if this is a model that flashes the clean light in blinking code for faults , then your not properly reading the flashing light , if it repeats the two - two flash rate this is an indication that its lost its communication between its internal circuit boards (most times this is a logic board problem ) but it can be the other ones as well or ive even seen a wet cable do this as well , if the flash rate is 1 flash - two flash this is an indication that there is stuck key on the keyboard (or a cable problem too )
but the Number one problem I see with dishwashers is there's water(or had been) where it should not be !! water in the wrong spot causes all sort of gremlins to show up and it doesn't take much just one drop and its chaos
Apr 13, 2016 | Whirlpool Dishwashers
My whirlpool slimline dishwasher is showing E4 and trips mains when switched on
frothing or water level high. Possible cause using tablets instead of powder or liquid. Take a look at this post.
Whirlpool ADP6000IX dishwasher Kitchen Home
Jan 17, 2015 | Whirlpool Dishwashers
Why would a whirlpool adp6000ix detergent door not open
The dishes/pans you stacked to be washed may have moved and a handle is hugging the bottom drain preventing opening the door. The real main reason is like a car door breaks and it will not open on the outside well the door on dishwasher can break too. When its old then it telling you to update.
Apr 29, 2014 | Dishwashers
Our whirlpool dishwasher make ADP6000WH/ADP6000IX runs for the first few minutes of each cycle the just kind of pauses and will not finish the cycle
Check your FLOAT... When it stops, Open the Door and see the Water LEVEL.
If the Water LEVEL is normal, then you have a problem with your Circuit Board
Apr 09, 2013 | Dishwashers
Whirlpool dishwasher ADP6000IX error3
see page 6 on this user manual for description of error 3.
Sep 21, 2012 | Whirlpool Dishwashers
Whirlpool adp6000ix not cleaning properly
I would suggest getting a de calcifying agent and putting the washer through several cycles. Sounds like the dump valve may be getting plugged up.
Sep 06, 2012 | Whirlpool Dishwashers
ADP6000WH/ADP6000IX--Whirlpool Dishwasher.(new) My problem--Water not getting hot--i have it connected to the cold water--should it heat the water ?
9d561c5b-7c7e-4515-8a01-fbfa8f762c34.jpgerror 3 not heating..on wix6000 /or / ADP6000WH
same boards .
rip out the the main mother board with all the black boxes ,and the transformer on it,,there is 1 black box its the biggest of them all ,next to the fuse with the blue cover on it ,with care take the black cover off with a screw driver carefully, not to damage the lower half of the internals,the lower section must not be damaged all ,once the cover is off you will see a copper coil on one side and on the other a set of breaker points ,at the end of the points ,get a screw driver and push in the outter point inward just a fraction,and bingo it will work again,of coarse its a temp solution,you will need to get a new breaker box from tandy or dick smith or simlar place to keep it going long term ..
hope this helps guys and gals ,please take extream caution when working on such dangerous power sourses ,and always make sure the power cord is removed before and repairs or tweeks..
cheers
Sep 30, 2010 | Whirlpool Dishwashers
My dishwasher is coming up with a error 4. my dishwasher is a whirlpool ADP6000WH/ADP6000IX please help
Aug 05, 2010 | Whirlpool Dishwashers
Problem with whirlpool dishwasher ADP6000IX stuck on drain mode has err4 on it which means water inlet problem has sencer that changers to pump mode now is stuck on pump
Hi I had the same problem with a whirlpool adp6000ix. Although it looked fine from the inside, the base was full of water. I managed to fix the problem by pulling the dishwasher out and then tilting it gently to the side. All of the hidden water in the base poured out which cleared err4. It is now working fine. Tip: Make sure you have a couple of towels spread around before you tilt it. Good luck!
Aug 07, 2008 | Dishwashers
WHIRLPOOL DISHWASHER, ERROR CODE 4, ADP6000IX MODEL
I have the solution! Had error 4 and had the repair guy come....he said its caused by too many suds...if you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completly) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone! Easy Peesy. I called whirpool about this, and why they could not tell me how to fix it is beyond me......they told me to press and hold the start button...i dont think even they know how to fix it! So...I got to do this under warranty, now hopefully you get to fix it for free and we all win. Yay!
Apr 09, 2008 | Whirlpool Dishwashers
Dishwashers Logo
2,563 people viewed this question
Top Dishwashers Experts
