Question about Avanti FF1101W Top Freezer Refrigerator
Not cool fridge is not coolong and its making a ticking sound
  • 15 Answers
By any chance is the ticking sound coming from the defrost timer, down in the freezer compartment? If the timer isn't advancing, either there won't be any automatic defrosting and the evaporator will turn into an iceberg or (if the timer gets stuck in permanent defrost) the compressor won't come on.
Defrost timers have a knob (sort of) that you can turn with a screwdriver (in one direction only). That allows you to move the timer in and out of defrost mode for troubleshooting. You can also mark the knob with a Sharpie and watch for the mark to move. These timers are supposed to make a revolution in 6 or 8 hours, depending on the model.The defrost part of the cycle usually lasts less than half an hour.
The defrost timer isn't the only part that can fail and prevent defrosting, but it's the only one likely to tick.
Posted on Dec 15, 2009
My Fridge isn't cold anymore, what could be the issue?
call a repairman , sounds like it need freon added
Nov 17, 2015 | Refrigerators
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Fridge and freezer stopped onGE Profile Psc23NG side by side. Turned off. It then started cooling and free
I need more info did you let it stand for a day or so ,if so you may have a defrost component failed which would explain the icwe melting from the evaporator and clearing the fins alowing the cold air to circulate once again ,if it is what Im thinking then it will clog up again and stop working
Sep 26, 2012 | Refrigerators
Intermittent Cooling
try them online next time might help.
Aug 06, 2012 | Fisher and Paykel Refrigerators
Fridge made a burning smell, and now makes a Tick, Fan runs on...
Sounds like the start relay has become bad/defective and it should be unplugged until we can have a look at it closer to see if possibly something other than the start relay is the reason for causing this failure. Depending on your model number a defective defrost control board or fan could start this cycle of damage to the compressor start relay and compressor if not unplugged until repaired. Please see if you can find the model number and I will be able to tell you more about the cause and assist you in the repair, Thanks, Sea Breeze
Apr 25, 2010 | KitchenAid KSRA22CN Side by Side...
Hi! My fridge just keeps making a ticking sound. It usually makes that sound for a bit and then the fridge "turns on". The sound is coming from towards the top of the backside of the unit and I have...
compressor won't start. Check the start device on compressor: Unplug the fridge, remove the cover on back, on the compressor (roundish black metal thing) there is a white box or brown relay with wires attached to it. Remove it and shake. If you see sand falling out of it - replace the start device. Model# is necessary for correct part number
Jan 12, 2010 | Refrigerators
Loud continuous ticking sound, freezer cold but refigerator warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 27, 2009 | GE Profile Arctica Stainless Steel Top...
Timer is making ticking noise cant turn it off.
My same oven makes a ticking sound when you tell it to start pre-heating the oven. The oven continues to make this ticking sound until you stop the oven and it completely cools down. This ticking sounds to be coming from the oven control panel. I have no solution, but I'm glad I wasn't the only one who had a problem with this ticking sound!
Jul 15, 2009 | Ovens
My fridge keeps making a ticking noise, sort of
The evaporator fan, inside the freezer will sometimes come in contact with ice and make this noise.
If the overload on the compressor is tripping it will make a clicking sound.
Mar 04, 2009 | Frigidaire Gallery Series® GLHT186H Top...
Avanti FF1101W Top Freezer Refrigerator Logo
219 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
