Question about JVC Audio Players & Recorders
Stereo Reciever model CA-D4T:cd changer won't "read cd" and sometimes says "no disc" when thereis one in there! Sometimes out of the blue it will work but mostly not! Any help would be appreciated ....I like this stereo that I got in 1995-96
  • graciethecat Jul 30, 2008
    any help here?? It will work once every blue moon but mostly NOT!
  • 4,234 Answers
This is an indication that either the lens is dirty or that the optics are failing. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics will need to be replaced.
Dan
Posted on Jul 30, 2008
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
Sep 27, 2011 | JVC AM FM CD DET FACE CAR STEREO
Err message on 1999 Jeep Grand Cherokee 10 CD changer
I had a similar problem which responded to the use of a CD cleaner disc to clean the laser lens reading the CD. The "err" messages stopped and the changer started to work as it had before. Perhaps this will correct your problem too.
Aug 02, 2009 | Jeep AM/FM Cassette with CD Changer...
The cd changer can't be read.
Find the RESET button, in sometimes is on the display,or in sometimes is on the cd changer,good luck.
Mar 23, 2009 | Kenwood KDC-C515FM 10-Disc CD Changer
My JVC stereo receiver :CA-D4T has 3 cd changers and they don't seem to work most of the time
Dan
Jul 30, 2008 | Audio Players & Recorders
Loading disc
First try to clean the laser lens. There are disc's you can buy for that purpose. They a tiny little area on the disc that has some very fine brushes that will clean the lens somewhat. It is not as good as having a technician clean it, but it can help.
Sounds like you may have a bad laser pick up or spindle motor, sometimes it can even be something in the servo circuit for the laser or the dsp ic.
since it loads everything good, the only thing you can do to ensure it is not something simple is to make sure the disc's are not loaded the wrong way and they are clean and scratch free as possible. Sometimes a fingerprint or scratch on a disc on the inner most part of a disc will keep it from being able to be played. That is the area the TOC (table of content) is located. If the laser can't read that area, it can't read any of the disc.
Hope this was helpful, I have repaired lots of cd changers and players over the last 15 years and if it is not something simple, then it will need to be serviced.
Jun 18, 2008 | Sony CDX-T67 6-Disc CD Changer
Blaupunk car stereo
There could be a loose connection somewhere.
Does the sound stops on a regular time interval or only on certain conditions?
Would there be a chance that there's water leakage at the area where the CD changer is stored?
Jun 08, 2008 | Sony XR-C5100 CD Changer
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
Disc Player not working
Please notify me when, and if, there is a solution. Thanks
Oct 06, 2007 | JVC MX-D4T Shelf System
228 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
