Question about George Foreman GRP4P Indoor Grill
Plugged in the grill for the first time and get beeps with "OP" displayed on the LED display. dont know what is wrong - any help will be appreciated
  • 368 Answers
Hi nph2go,
I can't be sure what you wrote because it got corrupted with HTML coding from the webpage.
It sounds like you want a manual with instructions (and hopefully some basic troubleshooting tips).
I'd contact the manufacturer (Salton, Inc.) customer servicesite for parts or manual. If they don't have them, they should knowwhere to send you (though if they don't, I'd seriously wonder about thecompany).
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Dec 31, 2008
Grill outage
I'm not sure what you mean by the Grill side. All the information I see for the SCE30600 shows a rather normal over with 4 burner stovetop, but nothing I would call a grill. Can you explain in more detail, or is it possible you chose the wrong model?
Sep 03, 2007 | Jenn-Air SCE30600 Slide-In Electric...
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
Aug 04, 2009 | Computers & Internet
CPU not boot up
First of all what exactly do you mean by "changed the CPU"? If its the processor? Is only the display not working, since you have said that the fan runs, it means the PC is starting. Check the Keyboard & mouse PS2 jacks. If there is any bent pins in the jacks? If so gently straighten with a pair of tweezers. Also try using a working Keyboard & Mouse from any other PC. If that still does not work, do you see the led lighting up on the MB? Does the MB make beeping sounds? How many? ALso mention the processor you have so that we may be able to help...............sodeep
May 08, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
OP Error on George Foreman grill model GRP99B
Hi srpaugh,
It might be fixable (I don't know your level of do-it-yourself skill or inclination, nor can I actually get my hands on it to tinker with it), but judging from the number of reports I've seen in the last couple of days on FixYa regarding these grills, there are some reliability issues that need to be resolved - - I'd be contacting the manufacturer and making them do the fix, particularly if it's still under-warranty.
Go to
Product Warranty:
Jon
Dec 28, 2008 | George Foreman GRP99 Indoor Grill
My display reads -SE-
-SE- error means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 28, 2008 | Amana AMV5206 Microwave Oven
Masterbuilt Smoker Model 20070108 Digitial Controller not working. Worked the first time, then no power. I hear a beep when I plug it in, but no display.
Take the display back to where you got it from and swap it out with a display model or something. Having a display that controls temperature and a timer is basic electronics in the modern world. Who ever builds these things should be ashamed.
Jun 22, 2008 | Masterbuilt ESQ30B Smoker
Kitchen Appliances - Others Logo
74 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
