Errors found:Code 8024402C Windows can't check for updates
  • 304 Answers
Description:
The 0×8024402C error code occurs because an incorrect character exists in the proxy override settings.
Possible Cause/s:
1. Incorrect character exists in the proxy override settings.
2. A misconfigured Proxy/Firewall can cause this problem.
3. You are trying to access Windows Update using VPN. The website and Automatic Update may not function properly.
4. The corporate environment does not have autoproxy implemented.
5. Your workstations sits behind a Microsoft ISA server.
Resolution 1:
Remove invalid characters from the proxy exception list and then clear the proxy cache:
1. Open Internet Explorer.
2. On the Tools, select Internet Options.
3. Click on the Connections tab.
4. Click on the LAN Settings.
5. Click on the Advanced button.
6. Please delete any entry in the Exceptions section.
Next, clear your proxy cache:
1. Click on Start, and then click Run.
2. Type cmd in the Open box to get a DOS prompt.
3. Type proxycfg -d at the command prompt, and press Enter.
4. Type net stop wuauserv at the command prompt, and press Enter.
5. Type net start wuauserv at the command prompt, and press Enter.
6. Now try the site again.
Resolution 2:
Reconfigure or update your firewall program:
1. Double-check the Proxy/Firewall settings. Add the following urls to the exception list within your Firewall/Proxy:
http://*.windowsupdate.microsoft.com
https://*.windowsupdate.microsoft.com
http://download.windowsupdate.com
Resolution 3:
VPN and Proxy.
Autoproxy is not picking up the wpad.dat proxy configuration file to determine the proxy to be used for the target URL. Thus we are going with no proxy!
1. Try to access Windows Update while not using VPN connection.
2. Use the proxycfg tool to specify a proxy server to use (proxycfg.exe -p <proxy server>). (contact your network administrator to find out the name and port of this proxy.)
This is every possible cause and solution for this error code and how to fix it. Please take the time to rate this Fixya for me for spending an hour researching every possible cause and solution for this code you posted for free, even if you don't figure it out. The solution to your problem is definitely here so read it carefully.
Posted on Jul 30, 2008
How do I Fix Windows Update Error 0x800F081F?
.NET Framework 3.5 installation error: 0x800F0906, 0x800F081F, 0x800F0907 Error code 0x800F0906
Error code 0x800F081F
Error code 0x800F0907 Resolution for Windows 10 0" style="box-sizing: border-box; outline: none;"> Error code 0x800F0906, 0x800F081F, or 0x800F0907
Error code 0x800F0922 More Information 0" style="box-sizing: border-box; outline: none;"> These errors may occur when you use an installation wizard, the Deployment Image Servicing and Management (DISM) tool, or Windows PowerShell commands to enable the .NET Framework 3.5.
In Windows 10, Windows 8.1, Windows 8, Windows Server 2012 R2, and Windows Server 2012, the .Net Framework 3.5 is a Feature on Demand. The metadata for Features on Demand is included. However, the binaries and other files associated with the feature are not included. When you enable a feature, Windows tries to contact Windows Update to download the missing information to install the feature. The network configuration and how computers are configured to install updates in the environment can affect this process. Therefore, you may encounter errors when you first install these features.
Error messages that are associated with these error codes
Error code Error messages 0x800F0906 The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
Windows couldn't complete the requested changes.
Windows couldn't connect to the Internet to download necessary files. Make sure that you're connected to the Internet, and click "Retry" to try again.
Installation of one or more roles, role services, or features failed.
The source files could not be found. Try installing the roles, role services, or features again in a new Add Roles and Features Wizard session, and on the Confirmation page of the wizard, click "Specify an alternate source path" to specify a valid location of the source files that are required for the installation. The location must be accessible by the computer account of the destination server.
0x800F0906 - CBS_E_DOWNLOAD_FAILURE
Error code: 0x800F0906
Error: 0x800f0906 0x800F081F The source files could not be found.
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
0x800F081F - CBS_E_SOURCE_MISSING
Error code: 0x800F081F
Error: 0x800F081F 0x800F0907 DISM failed. No operation was performed.
For more information, review the log file.
Because of network policy settings, Windows couldn't connect to the Internet to download files that are required to complete the requested changes. Contact your network administrator for more information.
0x800F0907 - CBS_E_GROUPPOLICY_DISALLOWED
Error code: 0x800F0907
Error: 0x800F0907
How to download the .NET Framework 3.5 outside of the Windows Update requirement
The .NET Framework 3.5 is available for customers with Volume Licensing or MSDN Subscription, as Feature on Demand Media is available.
Error codes are not listed when you install .NET Framework 3.5
When you install .NET Framework 3.5, you may encounter other error codes that are not listed in this KB, for more information, go to the following articles:
Dec 27, 2017 | Computers & Internet
Tip
How to Fix Blue Screen Errors (BSOD)
<p>Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.<br /> <p>There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.<br /> <p><b>How to analyze blue screen errors</b><br /> <p>The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.<br /> <p>Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.<br /> <p>Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.<br /> <p><b>The most common cause of blue screen errors</b><br /> <p>In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.<br /> <p>So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.<br /> <p>If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.<br /> <p>If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.<br /> <p>In most cases updating or reinstalling drivers will solve your blue screen errors.<br /> <p><b>Other causes of blue screen errors</b><br /> <p>However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:<br /> <p>Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.<br /> <p>Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.<br /> <p>Update Windows - missing updates, including service packs can be a source of stop errors.<br /> <p>Check your system - run a virus scan and spyware scan after updating your definition files.<br /> <p>Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.<br />
on Nov 29, 2010 | Computers & Internet
Fix error 8024402c
Click Start, and in the Search box on the start menu, type CMD, then press Ctrl+Shift+Enter (this will get you an elevation prompt for an Administrator command prompt)At the command prompt, type net stop wuauserv, then press EnterType rmdir /s %windir%\softwaredistribution\wuredir, then press Enter. Type Y to acknowledge the command.Type net start wuauserv, press EnterUse the Windows Update Web site again to install updates.Hope updates are installed.. If problem still occurs then run a system utility tool like Reginout for an instant fix.
Apr 21, 2012 | Microsoft Windows Vista Ultimate Edition
The engine service light stays on and blinks three times,goes off then blinks five times? code #35
This error code may be displayed if the device attempts to use one of Windows 2000's ... contact your computer manufacturer to obtain firmware or Bios update. (Code 35)
You can see the error code in the Device status area of this dialog box. Use the ... tab in Device Manager to configure the resource settings in Windows. Code 35
sounds like a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver also if you need to repair your bios
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS
BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps
May 01, 2011 | Computers & Internet
I can't install Windows updates and get error code 646.
1. If you Operating System is due to registry errors, you can try the registry cleaner @ http://windows-error-repair.org/error-library/error-code-646.html
2. Check your security programs eg. firewall or internet security programs, disable it and try Windows Updates.
3. Scan your PC for any Malwarewares or virus infections.
Hope it helps.
Sep 10, 2010 | Dell Computers & Internet
I am frank symborski.i have a gatway i got it on 5/8/08 no gt5670.it will not update.i have windows vista Home Premium With SP1.when i go to update,i get a cod,errors found ,code 80072EFD.can you hilp...
Frank,
The code 80072EFD means there is a internet connection problem. Verify that your internet connection is working, and then activate your Windows Vista again.
Nov 17, 2008 | Computers & Internet
Help with error codes
seems firewall is blocking the updates. or you have a pirated vista that wont update.
http://windowshelp.microsoft.com/Windows/en-us/help/261ae42d-8c84-496e-88cb-a46dff5504611033.mspx
Oct 05, 2008 | Computers & Internet
Computer Crashes -- error msg is that GEForce 4 (4000) is causing my crash
It may not be video card it could be system files at fault I had similar and some files were not indexed
go to C:\ right click Properties / Tools error check check errors new box opens tick the small square to fix errors and reboot while rebooting windows will scan disk and fix errors and if you are quick enough will see what it fixed then it will restart
I scan disk to fix errors every 3/ 4 weeks and do not have may problems
Aug 13, 2008 | Nvidia GeFORCE 4 MX440SE / 4000 / 4X DDR...
Computers & Internet Logo
533 people viewed this question
David Payne
David Payne
