Question about Frigidaire FGB24S5A Gas Single Oven
Gas stove works, but oven does not
Nothing happens when I turn my oven on. The heat source at the bottom does not come on and there's no gas odor. However, the gas stove still works fine, so I know that the gas supply is working. The electricity is fine because the digital display works. Please advise. Thanks in advance! stove works but oven does not
  • 2 more comments
  • boutwater77 Aug 31, 2008
    i see the ignitor come on, there is no gas coming because i put a lighter to the bar where the gas comes out and nothing. what does the ignitor have to do with turning on the gas valve?
  • kevpomp Oct 15, 2008
    ditto
  • jgould80 Nov 10, 2008
    oven heats when it wants to but not when i need it
  • Lislegarden Nov 24, 2008
    I have the same problem. Has anyone tried to replace the ignitor? Did it work? How to change it?
  • 135 Answers
You most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Posted on Jul 30, 2008
Nothing happens when I turn my oven on. The heat source at the bottom does not come on and there's no gas odor. However, the gas stove still works fine, so I know that the gas supply is working. The electricity is fine because the digital display works. Please advise. Thanks in advance!stove works but oven does not
Posted on Nov 26, 2008
2 Suggested Answers
  • 109 Answers
SOURCE: Gas stove works, but oven does not
yes replace the ignitor, this is the most common failures of ovens not coming on.
Posted on Mar 30, 2008
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Maytag Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Jan 18, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven - Very bad gas smell
Very Dangerous! turn off supply to appliance, supply ventalation and call service tech. If you are very familiar with gas appliances and know what you are doing then you can try to locate the leak using soapy water or leak detector liquid. make sure all flames and other possible sources of ignition have been eliminated. Keep room well ventilated. Spray leack detector on all fittings and look for leaks replace or tighten parts as needed. This responce is asuming you have not blown up already, seriously dangerous situation you have there.
Jan 07, 2009 | Ovens
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Dec 10, 2007 | Whirlpool SB160PEE Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
1,217 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
