Question about Konica Minolta bizhub C250 All-In-One Laser Printer
This is a c253 problem with negative images
I have a c253 that produces a negative image when running prints from indesign. The copier is equipted with the ic-409 controller(fiery). i have put all the patches on the controller. No other images from any other program seem to have the problem. is there a setting in indesign that could cause this? The image seems to more prevelant when you have a solid color background and white lettering. It also seems to repeat itself.
  • soup84 Jul 30, 2008
    i have also printed this same file on another c253 without the ic-409 and it printed fine
  • soup84 Aug 05, 2008
    I am apologizing for not putting enough information on my original posting. I am using the correct drivers for the fiery. I also sent the job from command workstation and converted it to a pdf. I disconnected the fiery and ran the same print job through the emperon controller. The ghosting problem is still there just not as noticable. I said i had run the same job on another c253 and the ghosting was not there, but i was wrong. It was harder to see. I ran the same job on a c451,c10 and a c6500 and the ghosting was gone. Possibly a c253 problem??
  • 167 Answers
It sounds like a driver issue to me. Are you sure you are using the correct driver?
Check the other computer that it printed fine from and compare settings/PPD.
You can also do a collect from both InDesigns and review the report file to see any differences.
There is a totally different driver that needs to be used if a Fiery is installed.
Also, you final line in the first posting sounds more like a "ghosting" issue and not an application issue.
I would deffinately identify the driver, you can download the driver files from the IC-409 by typing in the IP address in your browser and clicking on the "Webtools" logo. A pop-up will apear giving you access to the drivers and Command Workstation.
Have you tried opening and re-submittin g the file from Command Workstation?
You could also PDF the file and see if you get the same results, this will identify if it actually is an InDesign issue.
Posted on Aug 05, 2008
Bizhub c253 error code c4151
Motor inside the print head for cyan image unit is bad, Print heads are located below the image units one for each color. will need a tech to replace.Open close front door to reset
May 07, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Lost yellow and magenta in test print
Enter in the service mode and select tes mode select gradation test pattern and make a test for black,cyan,magenta and yellow.If the gradation is not OK you have change the bad imaging unit,or change the developer and drum in the bad image unit + the chip.
Mar 25, 2014 | Konica Minolta Minolta Bizhub C253 Copier
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
Aug 06, 2013 | Konica Minolta Bizhub C253 Copier
utility /counter, details, stop 00 stop 01,(SERVICE MODE) Image processing adjustment select all colors run twice ensure the image units are toned up for the gradation adj. Now run stabilization once. Now you will run the following three times (Gradation, Resolution, and compression). each. you will press start machine will run and print out a chart place the chart on the big glass do not use the document feeder use your best paper no color paper!!!!! ensure the black square are up against the scale on the left side you can use 11 x 17 or 8.5 x 11 paper 11 x 17 will give extra color strip not used 8.5 x 11 must be landscape. press start. In the end you should have 12 print outs 3 from each process.
Gradation, Resolution, and compression. once done print out a demo page in user mode check it out.
Feb 23, 2013 | Konica Minolta Bizhub C253 With Document...
I need 100% black high density prints from mac and InDesign/illustrator to make film positives for screen printing. What can I do or adjust to accomplish this? Thank you
Is it a text or an image or...?
If its just a jpeg you are putting through indesign, test its 100% K value using the dropper tool and hovering over the image.
If its text, or indesign generated,make sure the fill you use is 100% black, not 50% blue, 50% black which is often the default. Again, check the final using the dropper before you export the pdf.
I'm not sure exactly what your application is, but often for screenprinting, people duplicate the for instance two acetates of the same image one on top of the other to maximise the density....a friend of a friend apparently even uses 4 acetates layered up to be absolutely certain.
Jan 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Distorted image printing from InDesign to Xerox Phaser 8560
Have you tried a different driver? Most of those phaser printers have a PS driver loaded, See if there are PCL drvers for that product, and try that. I went on the site and they have both PS and PCL 6 and PCL 5 drivers, I believe one of those will help your problem.
Now that being said, If you are getting the stretching on other programs, then the problem is the drum motor encoder is getting contaminated with silicon lubricant from the maintenance kit. That will cause that problem, But since you are saying it is with one specific program, I suspect a different driver will correct the problem.
Sep 26, 2008 | Xerox Phaser 8500/DN Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Printing from Indesign CS3 to Epson CX11NF problem
Actually what i can suggest is that for you to try printing from a different application, such as microsoft word or paint. try printng a landscape image. now if its going to print it correctly call adobe since that might be an application issue. thanks for using fixya!!
May 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
Won't print when text on the page
Export the page as a jpeg, 150 dpi, high quality, then delete all the items on that page in the indesign document (text & images), then import the jpeg to that page it will fit exactly.
This works most times!
May 06, 2008 | Konica Minolta magicolor 7450 Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
328 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
