On the display a D looks much like an O. You probably have a DE error code which indicates a drain problem. Check your drain line, make sure the hose isnt kinked and the drain line is not blocked especially at the connection to the sink or garbage disposal. If that is all clear you may have a blockage in your drain pump....or the pump itself could be bad.
Hi
OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance.
Daniel
Hello & Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter by removing the bottom front access panel for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
