Question about LaCie (300740) 160 GB Hard Drive
Mac drive not reading on pc
I backed up my macbook on a Lacie deive not sure what format.
now my mac is in repair, I cant get my windows machiner to read it.
help!
  • 846 Answers
There is a software called macopener that let's you read mac formatted drives with a PC.
If that fails, and If the hdd is in device manager, than at least you can use carving tools like photorec to pull your files out, even if the filesystem is corrupt. If you want somebody else to do it for you you can check Data Recovery NYC. Otherwise http://hddguru.com/ is a great source for tools and knowledge on how to do it yoruself.
Posted on Jul 04, 2010
My Lacie isn't letting me move files onto it. I need to move movie files over from my mac to the Lacie, but it's not working. I had added .wav files a few months ago, and those are accessible, but now that...
did you use your drive with a PC too?
What you describe is commonly linked to a drive formatted as NTFS (a windows partition format) which is read only on a plain MAC system. There are add ons you can install on your MAC to make NTFS writable. I can direct you to one if you need.
Another possibility is that your drive is formatted as MS-Dos (FAT32) which is read and write enabled for both PC and MAC, but it has the negative aspect of limiting file size to 4GB. So in your case, maybe your movie files are larger then 4GB and your drive is formatted Fat 32.
To verify the format of the drive, go to DIsk utility, select the LaCie drive and read the information that shows at the bottom of the Disk Utility window.
Regards,
Jan 10, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Hallo, I have a LaCie Grand 1 TP external harddrive. I cant work in mine hard drive. I cant throw anything away i cant rename documents or put new ones on it. Some background info A few months...
Hi
you may face this issue because of differences between mac and windows file systems/partition table and security attributes that may disallow any further changes.
1-try to connect you HDD to a windows Computer and Backup all your files before loses any data(use more newer version of windows like windows 10 build 1709 windows XP is old/out of services and has many problems)
2-after a full backup in windows try to connect your HDD to your mac and format it via your MacBook
3- after formatting your HDD try to reconnect your HDD to windows and copy your files to HDD(windows has a compatible file systems that could read/allow/write mac file systems/partition and its attributes)
4-enjoy
best regard
Sep 27, 2017 | LaCie Grand 1 TB USB 20 Hard Drive
I have a lacie had drive that i've been using on my mac. My mac died and I bought a PC instead. How can I retrieve the data I stored on my Lacie?
The easiest way that I know is to purchase a program called MacDrive from Mediafour.com
This will let your PC (Windows XP, Vista or Windows7) read the mac formatted HD directly
They do have a trial version, so you can make sure it'll work for your HD before you pay for it.
Sep 06, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Mac problems
Hi Jay
Check the formatting of the lacie. Macs can read and write Windows formatted drives except those formatted in NTFS, which they can only read.
If you can read the drive, the chances are it's an NTFS formatted drive.
If you need to use it on both systems then you had better reformat it with the FAT format.
Jun 04, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 300790 that my Mac won't recognize
the Mac may not recognize it if it is formatted with NTFS. I believ most Macs can read FAT32 and other formats but not NTFS. You could hook the drive up to a modern PC, transfer the files there for a while, format the external drive to FAT32 and copy the files back to the drive. The Mac shold read them now,
Sep 21, 2009 | LaCie d2 Extreme (300790U) 250 GB Hard...
'not formated'
That's because your Mac was using a file system called HFSX. Windows uses NTFS. They won't be able to talk to each other without some sort of emulation. Check out http://hem.bredband.net/catacombae/hfsx.html for a free/open source app that you can install on your Windows machine that will read the data on the Mac-formatted drive. If you are just trying to get the drive to work and don't care about the data, right click on it from Windows Explorer, select "Format", then make sure you set it to use the NTFS file system.
Aug 09, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My lacie external drive cannot be located even though it is connected to my macbook. i can connect it to a PC with no problem but all tiff files are mac based so cannot open them in the PC. What should I...
Hook your drive back to your PC. Right click on it and check 'properties'. In the box that pops up if it says file system NFTS you are out of luck as that is a non mac compatable file system. If it says FAT32 it should be working on your Mac. If it says NFTS you'll need to transfer the files onto the PC reformat the drive using the LaCie software to FAT32 (the only file system that both Mac and PC can use) then transfer the files back to the external drive. Reformatting erases everything on the drive so don't forget to transfer the files first! I can place Tiff files into Adobe products on my PC so I'm not sure what you mean by Mac format tiff???
May 10, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a...
You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
Jan 08, 2009 | Computers & Internet
LaCie firewire 400 cannot be read by computer apple Mac g5
Whenever there is an HFS Volume could not be repaired issue, that means that your hard drive's existing volume has been damaged and may not be retrievable. In most cases like this, you would be advised to perform an Erase and Install to correct the damaged directory on your portable HD. However, as I understand that is not what you want to do, you may want to research Mac Utility software like these titles below:
Disc Warrior 4.1
font.f1 {font: 12.0px Helvetica}
(for Macs from Alsoft)
Tech Tools Pro 5.0 (for Macs from Micromat)
Drive Genius 2 - Mac (for Macs from Prosoft Engineering)
These are three of the better hard drive diagnostics, repair and directory rebuilding software on the market for Mac Users. I have used them a number of times as a professional onsite Certified Mac technician and they have helped me to help the customers I assisted many times over.
These Mac Utility software all have a price point of under $100.00 and when you are able to experience just how well they work, you find it is worth the investment.
an HFS volume error is repairable with the right software and these utilities are your best option aside from outright erasing and installing your Lacie HD.
Mar 29, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Open Questions:
LaCie (300740) 160 GB Hard Drive Logo
225 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
