Question about E-Machines eMachines Desktop PC
USB issue When I try to hook up my Zune mp3 player, it tries to install the driver but says an error has occurred. Something about it not being a registered service, I tried everything, including searching for the driver manually, still no luck. I also spent the good part of a day on the phone with Zune support and still nothing, help please? E-Machines Desktop T6216 Windows XP SP3
  • mandi86 Nov 22, 2008
    i temporarily changed my computer from vista to xp and i tried to install my zune again and an error keeps popping up. how can i fix this
    Sergeant:
  • 395 Answers
Hook up my zune and it recognized it first then disconnects with error "zune can not access important dat on your zune."
make sure it connected properly and make sure your connector is not broken... try to reinstaller of your zune...
Feb 28, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Device Driver Failed
You need to have windows media 11 installed. Can you try the player in another computer to see if it works there?
By the way is your vista updated to sp1?
www.windowsupdate.com
Jul 17, 2008 | Samsung Yepp YP-P2 Digital Media Player
USB Device has malfunctioned And Windows does not recognize it when I plug in Zune MP3 player. Have tried updating drivers and reinstalling them. I have tried unplugging the laptop and starting up not...
Try uninstalling the zune drivers
in control panel
add and remove
did you install any programs after the zune program
if so unstall them
then install the zune software form the zune web site
Jan 09, 2010 | Computers & Internet
My zune kills my laptop!
You need to either uninstall and reinstall the Zune software, test the usb ports with other devices to see if they kill the laptop and update the usb drivers if it does, or restore your computer, since it could either be a corrupted Zune driver, corrupted USB driver, or an issue with your operating system.
Oct 05, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
How can I fix Zune for c00d124d error
revisa la fuente de alimentacion y el panel de control
Aug 25, 2009 | Microsoft Zune JS8-00001 Digital Media...
Trying to plug in zune but computer won't recognize it.
You might need to reinstall the drivers, or update your USB port drivers.
A nice zune troubleshooting guide on this is available on fixing zune device errors.
Hope it helps.
Jules
Jul 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 4 gb Zune was charging and now it wont come back on!
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software
View products that this article applies to.
SYMPTOMS
When you try to use Zune Software, you experience one or more of the following symptoms:
• The Zune device is not detected by the computer.
• The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message:
No Zune device connected
• If you restored the Zune device software, the following messages are displayed on the Zune device:
Connect Zune to your PC
On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY
To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step.
2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position.
b. Press and hold the Back button as you press the top of the Zune pad.
When the Zune device begins to restart, release the buttons.
3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle.
6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base:
927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device
8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base:
941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista
If you are not using Windows Vista, or if the issue is still not resolved, go to the next step.
9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
b. Click Device Manager. Zune should be listed under Portable Devices.
Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device.
Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties.
2. Click the Driver tab, and then click Update Driver.
3. Click Search automatically for updated driver software.
4. Click Install if you are prompted to do this.
5. After the driver installation is complete, click Close.
If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver.
2. Click Browse my computer for driver software.
3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK.
4. Click Next.
5. Click Install if you are prompted to do this.
6. After the driver installation is complete, click Close, and then click Close again.
10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
c. Expand Universal Serial Bus controllers.
d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base:
310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager
11. Try using a different Zune Sync Cable.
Apr 10, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Drivers
Hey there seems that i have an easy solution to your problem here is how you get the drivers
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Microsoft-MP3-Zune-Digital-Media-Player-Driver-14.shtml
download the drivers install them on your computer and you are set. Let me know how that turns out.
Oct 02, 2008 | Audio Players & Recorders
Zune will not sync
Okay... what you do is Hold your zune in you right hand.. open the toilet bowl with your left.. put the zune in the toilet... and then flush it... or if you have not gotten a zune... just throw the $200+ in the toilet instead.. Because i have the same exact problem as these guys and none of their solutions have worked..
Feb 04, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
E-Machines eMachines Desktop PC Logo
73 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
