Question about InFocus Office Equipment & Supplies
Projector Lamp seems to go out after a few seconds to 1 minute
I have a Proxima DP1200x. At this point, you turn it on and the image is projected on the screen, but after a 30 seconds to 1 minute, the image is gone and the light goes 'out'. It sounds like the projector is still running though (although it could just be off and cooling down).
  • 1 more comment
  • cusher Jul 30, 2008
    I hear the fan and feel the air coming out
    Okay, so now it's been running no problem for about 5 minutes. I linked my laptop to it an it's been running for about 5 minutes..strange
    I will try! You think it's just dusty?
  • 2,071 Answers
I encounter like this problem before only i change bulb and clean the circuit board including the fan and do resoldering work's in the circuit board due cold solder and then its fine.I think this desame to your problem too.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the unit turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
Posted on Jul 30, 2008
    Genius:
  • 1,847 Answers
It seem the lamps are getting heated, do you see the fans functioning properly.
  • Legin Varghese
    Legin Varghese Jul 30, 2008
    I "seem" to have repaired an X350 with the same problem. You'll need a Torx T-8 wrench and a small pliers. Make sure you have a cup in which to place the screws. Remove the Torx screws from the top 1/2. There are 4 and one is shorter, so pay attention to which one that is. Also remove the top connector from the "Computer" connector. Remove the top. Remove the rubber pad from the tops and place it on the bottom where the "buttons" are (nothing sticks up, but they are drawn in). There are 3 fans on the right side. You can flip the pair up to look at them. Plug in the Proxima and turn it on. In my case all 3 fans worked. Blow out where you see dust. If you removed the large front fan, be sure the grommet for the 2 black wires is back in place. It goes in the U next to the fan compartment and the next compartment. The wires go through the hole in the middle. Place the rubber pad back on the top and press it into place. Put the top back on. If you are lucky like I am, it will suddenly work. Good luck!
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
We have multiple A1200ep Ask Proxima projectors. We are having a problem with two of them. They just shut off after a period of time even when your in the middle of using them. It's like the projector...
Clean air filters. DO NOT BLOW INSIDE!!!
Take the filter out andust it out somwhere outside.
If it does not help, more likely there is fault inside.
Possibly power supply.
Mar 07, 2011 | ASK Proxima DP1200x Multimedia Projector
Hi. I have a InFocus dp2000x. It has no lamp. I try with a flashlight in the lamp chamber (the flashlight is battery operated) When I turn on the projector with a vga or video input, the power led start...
Projectors are designed to be used with a lamp and will turn off when there isn't one present. You would have to purchase a new lamp to use the projector.
Feb 19, 2011 | ASK Proxima Proxima DP2000X Multimedia...
Ask Proxima A1200EP won't turn off.
these projectors have a habit of overheating and causing main board problems. it may need upgrading.
Mar 06, 2009 | ASK Proxima DP1200x Multimedia Projector
Proxima c420
yes. the lamp is starting to go.
Aug 19, 2008 | ASK Proxima C420 Multimedia Projector
Proxima DP2000x troubleshootind
Here is the link to the user guide. http://www.askproxima.com/service/c40/downloads/english_dp2000_ug.pdf i am having the same problem please post an anwer if you get one. -jackintosh
Nov 14, 2006 | ASK Proxima Proxima DP2000X Multimedia...
136 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
