Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Fuzzy double overlapping images.
My wife and I were watching TV the other night, when all at once the picture went fuzzy, it jumps around a bit, and the images are doubled or overlapping. After TV has been off for a while when it is first turned on the picture is normal but after a few minutes the picture goes out and it starts all over again.
This comes at a bad time for us as this friday my wife has to start taking chemo once every three weeks until middle of November. She was planning on watching TV to pass time when she is not feeling good.
We do not have anyone close by to fix this problem. Is it something I could do myself if I new what the problem is? I am a do it your selfer.
Thanks in advance.
  • alsharp Aug 01, 2008
    Thanks so much for your support and advice. You were 100% correct. There was a loose resistor connection. I soldered it, now the TV works great.
    Again, I thank you so much.
    Al Sharp
  • 927 Answers
Good Day, alsharp;
I am very sorry about the condition of your wife, I hope she recovers totally and my prayers are with you, your wife and family.
Do not turn TV on, the problem may get worse to the point where the TV may go DOA.
It sounds like you have some poor connections on the TV's convergence IC's. Since, you say that you are handy you maybe able to fix this yourself. If you own a good soldering station / pencil.
The convergence IC's will be located on the right hand side of the TV, looking from the back. They will be attached to a large silver device (heat sink). The IC's have 16 pins on each one, there 2 of them, side by side. Remove old solder and apply new.
I hope this was helpful. E-mail me at mmrkcar@yahoo.com for more info if you need it.
God Bless, big IRISH.
Posted on Jul 30, 2008
  • MICHAEL MULLINS Aug 02, 2008
    Good Day, alsharp;
    I am glad to be able to help you.
    Thank you for letting me know that I was helpful.
    Be Good, big IRISH.
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
I have a 2 year old LG LCD TV (model 42LG60) and I am having problems with the screen. I turn it on and everything is fine for a few minutes and then the screen goes to red or green lines that are fuzzy....
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
Oct 23, 2011 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
I have a DX-L26-10A that has problem with the A/V inputs. The picture is fuzzy. All the other inputs on the TV have a good picture. Both A/V1 and A/V2 are fuzzy.
AV1 and AV2 are Composite signals. What this means is that the Image signal and the Image color are combined into a single feed... or a composite or signal and color. Other than using CH3 from the cable box, this is the poorest performer in regards to signal quality. Additionally, the signal only has 480 lines of resolution and your TV has 720.
What all this means is that 480 lines of poor image quality are being blown up (think magnified) to fill 720 lines of resolution on the screen. What you end up with is a blurry image when compared to other inputs (ie: HDMI, COMPOSITE). The Dynex TV does not have some of the more advanced video processing of other manufactures. It will perform the image doubling, a bit of filtering, but not much more.
I suspect you TV is fine. A transition to an HD display can be shocking to some. After all, the VCR looked better on the old analog TV (not a joke, it did).
I hope this was helpful, best wishes.
Mar 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Monitor is fuzzy. A bit like double vision
Try moving cables around, may be too close to, another, power source. Plugs may be loose tighten.
Apr 30, 2010 | Acer AL1716 F Monitor
Poor picture (fuzzy ghost image/aura)
well you should check the settings and read menual
Jul 22, 2009 | Panasonic TC-P50G10 Plasma TV
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Fuzzy white lines
YOUR tv DEVELOP a problem in the video ocillator or the tunner section have this set check by a qualified tech.to solve your problem good luck.any more contact nicodhem@yahoo.com i hope by now you have gotten your set fixed the repairs will cost you about between $50.00.to $200.00 good luck.
Feb 25, 2007 | Sharp 32U-S60 32" TV
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
98 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
