Question about Brother SX-4000 Typewriter
Need to Replace Paper Supporter
Where can I buy a replacement paper supporter?
Mine broke and I don't want dust to get into the keyboard.
It's also a pain to take anywhere! : )
Thanks
  • 328 Answers
Try thrift stores, garage sales. No longer available from Brother.
Posted on Aug 12, 2008
Brother dcp 7040 prints grey film over the page
someone cheaped out and got the el cheapo paper.
The low quality paper has paper dust on every page....
when the printer feeds this cheap paper thru the machine it drops the dust onto the tonor cartridge rollers and causes the roller to accumulate toner on the roller... this in turn is transfered to the pages being printed.
check your machines operation manual. There may be a clean cycle you can try to run to clean the rollers...
I had to buy a new toner cartridge for mine when this happened.
Apr 17, 2013 | Brother DCP-7040 Laser Multifunction...
Fuser unit failure
Remedy:
1.Replace fuser unit
2.Check the harness connection between fuser unit connector and eject sensor PCB ASSY
3. Replace the PS PCB unit
4.Replace the toner LED PCB ASSY
5.Replace the main PCB assy.
You can try to leave the machine power on for 10 minutes maybe this can clear the error. Or power on the machine while pressing the SW supporter,when the front cover is open and check that toner, DRUM and error LEDs light up, and then release the SW supporter. Check that all LEDs go off and press the SW supporter once,and then this problem maybe cleared by that press the SW supporter once again after all LEDs light up.
Apr 14, 2013 | Brother HL-2170W Laser Printer
Forgive a naive question from a technical dud. My Laser MFD 6020 has worked well - until it began paper jamming today. I can't easily pull the paper out frontwise without seeming to do violence to...
clean any paper dust from the paper path, something is blocking somewhere,
theres too many factors to give an exact diagnosis...but !!!
if the paper is
completely blank where jamming it maybe time to order a new set of pickup rollers, which just collect the paper from the bottom drawer, should just pull off and easily replaced and are cheap, you can clean these with soapy water as long as you thoroughly dry them before putting back.
if the toner is on the paper but its not dry...smudgy, try the transfer drum, either check theres no small tears of paper or excess dust in that area,(DON'T CLEAN WITH CLOTH relies on static charge) a few light blows of air should be enough..replace if need be but they're expensive.
if the papers printed and dry where jamming its going to be in the area of the fuser (the hot roller) this can be cleaned with dry clot, don't use any solvents ore cleaning products...ALLOW TO COOL first or burn your fingers.
if the papers crumpling anywhere along the line there is a roller not turning maybe due to a stuck piece of paper from a previous print, the roller not turning is obviously between the front of the paper and the crumple.
Apr 20, 2011 | Office Equipment & Supplies
Rubber paper feed band broke on my Samsung ML 2010
The part you need is JC73-00211A. You can buy this at printerBuddy.com. If you wish to replace this, follow this link for instructions in order to replace it. http://www.fixya.com/support/t446286-samsung_ml_2010_feed_paper
Hope this helps.
Jun 29, 2010 | Samsung ML 2010 Laser Printer
Paper sensor failure!
Try this it may work. Take your hairdryer, Hi setting, Blow through the paper slot. Sometimes dust accumulates on the sensor eye. If you are out of warranty it may not be cost effective to repair.
Jun 29, 2009 | Fellowes 3011001 Shredder
Hi I have a Konica Minolta 2490MF and when I try to print a document/s it will print the first page only then comes up with an error 'incorrect paper size (1LT)' the paper size is correct (A4) and the...
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
My diNovo mini Bluetooth 2.0 # 830-000034 usb is broke
You can order the USB for $10.00 on the website. Also you can return the entire product to the store you purchased it from and they might replace it. I broke mine and tech support sent me another free of charge. I thought it would take too long for delivery so I returned mine to CompUSA and they exchanged it wihtout a hassle. I recently broke mine again(girlfriend dropped the laptop with the USB attached) two days ago and I am trying to find the extra one tech support sent otherwise I will order one for $10 this time around. Hopefully this helped you out some.
Mar 27, 2009 | Logitech diNovo Bluetooth Media...
Same problem with mine
i think your fan is not working
and dont kept on metal
Mar 10, 2008 | Computers & Internet
Paper Roll Replacement
i work i mservice ,but for that model i don`t have a holder,but if you want i vill send you a universal holder.
beljin sasa
sbeljin@mgnet.co.yu
Feb 01, 2008 | Victor 1240 Calculator
Brother SX-4000 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
