Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Filter? Is there a filter I should be cleaning out periodically?
I have been told that there is a filter on a washer that should be cleaned periodically but I can't find one in the instruction manual nor in the washer.
This is a Whirlpool Ultimate Care II - commercial quality - 21 cycles - 6 speed combination. Can anyone tell me?
  • ejmico Jul 30, 2008
    This was so nice of you to answer what probably sounded like a stupid question. But a neighbor insisted that every washer had a filter. So thank you very, very, much.
    Elva
  • 135 Answers
There is no filter to clean in your machine.....any lint or other build up is designed to go out with the drain water...
Posted on Jul 30, 2008
  • calving_brow Dec 20, 2010
    Then how Do I solve my lint build up problem?
Water not draining
Remove the bottom panel. Screws are located on the bottom edge. There is a filter that needs to be cleaned periodically. Have a large pan ready to catch the water that will come out of the machine. A few towels might be a good idea as well. Open (unscrew) the filter cap and remove/clean the tray. Check the drain tube that leads into the filter for blockage. I have found entire pencils in there. This info is not in the manual. A GE service tech told me about it.
Nov 24, 2013 | GE WSXH208A Front Load Washer
I have a kenmore front load washer. I was told to remove the kick plate to check the filter but my manual has no instructions.
You need to remove the lower front panel (three small screws at floor level) after removing you will see the drain pump right there in the middle. Place a shallow pan under the front of the pump, then remove the cap on the front of the pump,clean out all the debris and wash off then line up the marks on the cap and housing to reinstall That's all there is to it.Good Luck
Nov 14, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
I have a Samsung WF448AAP/XAA washer. I have had it for a year + and have never cleaned the filter on the bottom of the machine. Tech support told me to clean the filter. Dumb, I know, I just didn't...
There is most likely something stuck in the rubber hose between the drum and the pump, Unfortunately this is not easy to get to as it requires tilting the machine back and climbing underneath to remove the hose and check it. Make sure you disconnect the power before doing this.
May 08, 2017 | Samsung WF448AAP Front Load Washer
Determine venting requirements
When you initially unpackage the microwave oven it is already set up for RECIRCULATION mode (which is VENTLESS). However, since the unit recirculates air rather than exhausting it out through the wall or roof, it usually uses a couple of small charcoal filters behind the upper grille and mesh filters on the underside that have to be changed or cleaned periodically. These filters will accumulate grease and dirt over time and should be periodically checked in order to maintain proper ventilation and air flow. Information pertaining to the location and care of the filters is explained on Page 4 of your Owner's Manual.
NOTE: If you wish to convert to a VENTED system, the instructions are listed on Page 4 of the Installation Guide.
If you do not have either manual you can obtain copies at managemylife.com. Just type in your model number as "GMH3174XVB" and you will find the manuals listed in a .pdf (Adobe) format that can be printed or downloaded for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 25, 2010 | Microwave Ovens
I have a LG TROMM WM2277HB washer, and the water did not run through all clothes to clean the whole load lately. I had an appliance specialist come today, and he checked and told me to replace a...
THATS A RIP! THE PUMPS ARE ABOUT 65$ THERE IS A CLEAN OUT ON SOME MODELS BEHIND A DOOR IN THE FRONT BOTTOM OF YOUR WASHER. INSTRUCTIONS SHOULD BE IN YOUR MANUAL
Jan 12, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Where is the filter
The filter is located at the rear`of the washer.
To access it, remove the rear lower panel.
You will see a large black hose, remove hose from bottom of tub, and you will find the plastic filter inside, remove filter and clean.
Refit filter and hose, and test.
If it still does not spin, then you need to check the brushes.
If you require info on how to check and change them, then let me know.
Please rate my fixya solution.
Thanks.
THanks.
Feb 10, 2009 | Creda W100FW Front Load Washer
Foul smell coming from washer
Run a vinegar wash periodically. My mother has an upright that was doing the same thing and all the repair man told us was to not use powder detergent, clean the gasket, and do the vinegar washes periodically.
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
FO2 AND SUD
hAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
Dec 23, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
Dec 11, 2007 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
538 people viewed this question
Dan Webster
Dan Webster
Sal De
