Question about Maytag MMV5186A Microwave Oven
Mvp Iv microwave oven model vm12av-1
The light works and the timer counts down like it would normally but thats it.
  • Maytag Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
Jul 04, 2014 | GE XL1800 1100 Watts Microwave Oven
Need to replace MVP IV microwave CMV1000ADW...what is comparable in size that would fit bracket?
I would contact customer service and ask if they have "drop-in" replacement.
That was a Daewoo made for Amana / Maytag / Whirlpool.
Their customer service is here.
Jun 08, 2013 | Microwave Ovens
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
We have Maytag Model: VM12AV-1, microwave oven. This morning when I pushed the start button to heat for a 40 second period all powwer on microwave went out. I checked the power outlet to oven, and we had...
All the possible problems will mean removing that is likely that a fuse inside blew, but that may be a sign of bigger problems...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Oct 04, 2010 | Maytag MMV5186A Microwave Oven
My mvp IV runs but does not heat the food, all the other functions work. any sujestions
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sep 09, 2010 | Maytag MMV5186A Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
How do I order replacement grill and trim panel for the microwave MVP IV Model 10007353QK
> Model is VM12AV-1.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
You can download Maytag owner's manuals and installation instructions here. They will show you how to remove the grille, etc.
Jul 18, 2009 | Microwave Ovens
MVP Iv vm12ab-1 microwave
I have an MVP III Magic Chef microwave for the past twenty years. Every Function on the smartboard works except for the start button. We've been told that the smartboards for this model have been discontinued. I recently tried to find the part online and my search was not successful. Any ideas on how to proceed to get my microwave up and running again...
Jan 19, 2009 | Maytag MMV5186A Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Maytag MMV5186A Microwave Oven Logo
1,280 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
