Question about HP Photosmart 8250 InkJet Printer
Ink system failure, error code 0XC18A0506
I've read some other reports of the same problem on your site and as of April 18, one other guest said that the solutions listed for ink system failures didn't work for him. Can you offer any other advice besides what is on the site (and doesn't work)?
Scott error code 0xc18a0506
  • 20 Answers
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Posted on Jan 02, 2009
I have a problem with my printer,when i click print page i have got a problem with ink system failure and Eror 0xc18a0506, can someone help me to resolve the problem?
try the following.
Open site http://narod.ru/disk/2579842000/FirmwareEnable_Release.exe
Then scroll page down, type to textbox the numbers on picture above and press green button (CKA4ATb).
On next screen remove checkbutton (YctaHoBNtb RHAekc bap) and press on file link above it.
It's the same file as in birseyindir.net site.
I'm warning, your printer will not work, if there is some real physical problem. In my case it was unused long time without cartridges and black ink was completely dry inside of printhead. I opened it carefully and dissolved it with spirit.
Oct 14, 2013 | HP - HP Photosmart 8250 printer
Hp photosmart3210xi all-in-one Error 0xc18a0506
Hello Javier! Welcome to FixYa!
Error 0Xc18a0506 in usually a Ink System Failure error
You need to do some basic troubleshooting steps below and hope that it would fix the problem:-
  • Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
  • Open the cover of the printer and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the printer and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify printer is functional.
  • Reconnect the USB cable, and try to print from the computer.
I hope this solution helps you and you have clear picture in your mind now
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Jan 06, 2012 | HP Photosmart C6280 Printer
HP Photosmart error code Oxc19a0002 what does it mean?
This error code indicate a failure in the ink system. If you've tried with different/working cartridges, please follow the instructions given HERE.
Good Luck.
Thanks for using FixYa.
Jul 17, 2011 | HP Photosmart 3310 Printer
Ink system failure 0xc18a0506
The "ink system failure" error is caused by air in the ink feed tubes.We have a guide to help you purge the air from the feed tubes posted on our web site at: http://www.ccl-la.com/hp_c5180.htm Follow the steps and you should be printing again in no time.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Over 21 years of PC and printer support/service
Dec 16, 2009 | HP Photosmart D7360 All-In-One InkJet...
Ink system failure, failure code Oxc19a0035, if i turn it off and back on it will work for a day then the code comes back up.
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart 8250 Ink System Failure,error code Oxc18a0007. I've tried HP site for solutions with no success. Also tried re-installing software,replacing ink (all genuine HP) but no luck!
Jun 17, 2008 | HP - HP Photosmart 8250 printer
HI,
I do understand that fact that it did not work out for some other users , reason being the error which u are reffering to is related to the hardware of the printer . but it might work in some cases u may try the steps to reset the printer .
u can reset the printer to its factory deafults as well
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Thanks
May 21, 2008 | HP Photosmart 3210 Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart 8250 InkJet Printer Logo
2,852 people viewed this question
Ben Johnson
