Laptop keyboard replacement procedures are all similar,
Search on the internet for how to replace ne552 keyboard (or similar). You my find quite a number of nearly relevant instructional videos and step-by-step instructions, referring to slightly different models..Look at a few and see how similar they are, pick one and follow it eg Replace Keyboard Gateway Laptop or Replace Keyboard on Gateway Laptop NE56R
What you really need is the maintenance & service manual, but there doesn't seem to be one. You might try contacting Gateway support and asking.
Keyboards for your model are readily available, on ebay or from commercial parts suppliers, even Gateway
PLEASE PUT ALL SCREWS BACK IN...YOU NEED TO WORK FROM THE OPEN COMPUTER ON TOP, NOT THE BOTTOM!
SLIDE YOUR FINGER ACROSS THE VERY BOTTOM OF YOUR SCREEN...THERE WILL BE A SMALL BUMP/MARKING STICKING OUT...
JUST UNDERNEATHTHIS BUMP...ON YOUR KEYBOARD PANEL WILL BE A SMALL PUSH TAB..YOU WILL NEED TO MAKE SURE YOUR SCREEN IS LAID BACK...OUT OF THE WAY...SO NOT TO SCRATCH IT ETC,. ALSO TO HELP GET TO THE TAB.
CAREFULLY USE A SMALL TOOL/FLAT SCREWDRIVER ETC.,..TO PRESS THIS PUSH TAB...
LIFT UP THE SMALL PANEL THAT HAS...(THE POWER BUTTON & ADDITIONAL (4) BUTTONS..EMAIL, WEB,ETC,. )...ONCE YOU RELEASE THIS SMALL PANEL...(THERE MAY BE A COUPLE OF SCREWS THERE TO REMOVE)...TO LIFT THIS PANEL.
GENTLY LIFT UP THE KEYBOARD PANEL...YOU WILL SEE WHERE YOU NEED TO DISCONNECT THE KEYBOARD,..PLEASE MAKE SURE YOU MARK YOUR PLUG WIRES WITH TAPE AND WRITE DOWN WHERE TO RE-INSTALL THEM.
(NOTE)...THIS IS ALSO THE WAY TO CHECK YOUR FAN AND MAKE SURE IT IS CLEAN AND WORKING PROPERLY..
IF I CAN BE OF FURTHER ASSISTANCE, PLEASE DON'T HESITATE TO CONTACT ME!
the problem may be of the sticky keys or of the keyboard. no else problem is seen in the keyboard.. so, if sticky keys are enabled, disable it from the accessibility options in control panel else change the keyboard !
Sounds like you have turned on the NUM LOCK on the laptop keyboard. If
you look closely you will see the numbers on those keys (maybe in a
different colour).
You need to turn off NUM LOCK again. On the
laptop I'm looking at, this is done by pressing Fn and END together,
but the key should be marked with NUM LOCK as well.
your keyboard is in other language. you just go to the note pad and check all the keys with shift and without shift key... if not appers then copy the ? mark and past it where u want...??????????????
did you check your keyboard settings yet? At Control Panel --> Keyboard - there you can adjust the keyboard delay. That could be the problem. Give it a try and let me know.
