If its F2- 31 , its the drum mark problem.The drum may be defective or the wrong drum fixed on a machine.Also clean the drum mark sensor on the drum unit.
Hi, My name is Julio. I got an old EP2010 Copier and i used to use it till this morning I get the...
(More)
Hi, My name is Julio. I got an old EP2010 Copier and i used to use it till this morning I get the C00-00 code on the display every time I try make a copy. I did two copies this morning, then tried another copy and faile. Need immediate support
Error code P appears when switched on and goes out for 1 copy only when cancel button pressed.It...
(More)
Error code P appears when switched on and goes out for 1 copy only when cancel button pressed.It will then print 1 copy and reappear. How do I cure this problem?
