The desktop no longer extends to the left side at the 1440 x 900 at 60 hrz resolution. There is a black vertical stripe on the left. I don't know what happened. I've set the horizontal position at zero, but still have the stripe.
This problem,could be a problem with the monitor or the graphics card. You need to test your computer with another monitor at the same setting to see if the graphic card is having a problem with the setting. Also test the monitor on another computer with the same setting and see if you still get the problem. You can also try using a different graphics card in your computer to see if the graphics card is having a problem. Setup the new card for the same settings and see if you still have the problem.The customer support telephone number for Envision is .1-888-838-6388. Their customer support website is. www.envisiondisplays.com. They should be able to help with your problem.I hope this information helps you with your problem.
I only get a all-white screen. But I can still take pictures and see them on my PC. WHat can I do? I...
(More)
I only get a all-white screen. But I can still take pictures and see them on my PC. WHat can I do? I bought my camera 2 years ago.
the on/off switch on my mikomi 15lcd 250 has broken.i beleive that there is a replacement patr(no...
(More)
the on/off switch on my mikomi 15lcd 250 has broken.i beleive that there is a replacement patr(no 17tk16)available, where can i buy this
question: monitor says: "cannot display this video mode, optimum resolution recommended...
(More)
QUESTION: Monitor says: "cannot display this video mode, Optimum Resolution recommended 1280x1024 60HZ. How can I change the resolution if I cannot see the monitor?
