Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Repeatedly blowing R842
I have replaced the amplifier IC's and the one resistor (R842 - 1.8 ohm) that was open. When I hooked everything back up, the picture was fine for about 10 seconds and the same resistor blew again and the picture was back to being bowed in at the top and bottom in the green. I replaced the resistor again and the same thing happened. Where should I check further for the source of the problem. Obviously, something is wrong elsewhere to keep blowing the same resistor. Any help will be greatly appreciated. If you want to email me, I am charles dot vance at westknox dot net. Thank you for your time and expertise.
  • 4 more comments
  • CVance Jul 30, 2008
    I checked the capacitors on the convergence board and cannot find any that look like they may be leaking or swelled up or anything else out of the ordinary. I was mistaken in the resistor number, it is R862. In tracing the lines on the circuit board, it appears to go from the amplifier IC to the green output plug.
    Thanks,
    Charles Vance
    Thanks,
    Charles Vance
    I will order a manual. Meanwhile, any other ideas I can check into?
    Is the amplifier itself the large square metal plug in box on the convergence board?
    I have a service manual on order.
    Is the amplifier the standup silver enclosed "module" that is not soldered onto the board but plugs in as a computer card would? If so, is this serviceable, as in checking resistors, etc?
    Also, since the resistor that is in question appears to go to the small cable for the green projector, could there be something in the green projector that is causing this?
    I am going crosseyed watching the messed up picture, so I am desperate to get this tv fixed.
    The resistor I replaced the bad one with was a 2 watt resistor, the original was a 1 watt.
    Genius:
  • 1,011 Answers
Dear,
is the resistance value is ok. if its exatly the same then check the wattage of the resistance. may be you are using the low wattagel resistance. resistance blows only if the heavy current (more than it rating) flow through it. check by using a high wattage resistor of the same value.
regards,
Posted on Jul 30, 2008
  • 2,326 Answers
I can send you the service manual.
Double check the solder as well and make sure they are not shorting out.
I would suggest to desolder pin # 7 and 9 from IC804. Also try to remove the wire that is connecting to the green convergence yoke.
  • Jaime Hernandez Jul 30, 2008
    Do not touch that silver square box, the failure is not there.
  • 3,037 Answers
Quit replacing the resistors, this can make it worse. What ever the fuse relays to must be replaced. Seems like it is the Amplifier since you replaced the ICs for it. Let me know if you have any further questions and good luck
  • Benjamin Patri
    Benjamin Patri Jul 31, 2008
    I just reread your first post, Is the green the only one out of
    alignment? If so then the amplifier is not the problem. ICs that
    generally are at fault are on the digital convergence board but since
    you replaced them, then I would actually turn to the green projector
    like you said and try replacing that. There must be a short in it or in
    the cable going to it.
    Genius:
  • 2,035 Answers
This could the problem with short in the board you need have service manual to verify the problem you get one from this website:
http://servicemanuals.vstore.ca/
Good luck....
  • 2,071 Answers
It is the capacitor caused that's the resistors blows,because the the capacitor cannot hold the storage voltage that why he passed it to resistor then the resistor can't also that why it's blow.Look for the capacitor associated to that resistor trace the line,for dryed up and leak capacitor...
Hope this may help;
Regards,
VOTIT
Describe how to connect a scosche 500k micro farad
Put the capactior in parallel with your battery right before the amplifier. So Postive lead of cap to your 12 Volt line and negative lead goes to ground. It is also suggested that you charge the cap before placing it directly in parallel with the 12 volt rail. yo ucan do this by using a 1000 ohm resistor with a power rating of 1 watt. Disconnect your amplifiers so it is just your cap and battery. Replace the fuse with the 1000 ohm resistor. Once the resistor is in place hook up your cap. It will take a little bit for it to charge. RC time constant is T = Reistance X Capacitance. So 1000 ohms X .5 Farads = is about 8 minutes, or you can just measure the voltage with an volt meter and when the cap reads 12VDC you can then hook it up. BE CAREFUL NOT TO SHORT TERMINALS. THIS CAPACITOR I STORING A LOT OF CHARGE.
Jan 26, 2010 | Car Audio & Video
2.2 ohm resistor blowing after convergence repair
It might be the issue on the board. I would recommend you to show it to a repairman
Sep 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I just replaced the convergence board on my JVC AV-56WP74, but the red still won't line up. Are there other parts that should be changed?
you also need to check and replace low value resistors in that circiut.they are all 1 watt,usually they get discolored when stressed.R842 2.2 ohm,R854 and R846 1.5 ohm,R850 2.2 ohm,R858 3.3 ohm,R862 1.8 ohm.they must be the exact value available in MD from surburban electronics.please note stk392-110 upgrade to stk392-150 for future referance.ONCE AGAIN CHECK ALL LOW VALUE RESISTORS
Sep 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Marantz SR19 no sound?
When replacing output transistors on amplifiers it is generally a good practice to replace the output capacitors as well as the biasing resistors. Just because one transistor is bad does not mean that that is the whole problem. Look for what caused the problem. Bad speakers,bad wires,defective traces on circuit board,poor soldering. Also when mounting the transistor make sure it is insulated and grease it with a dab of silicone heat sink compound. Whenever I service a board I examine all components for tolerance as well. A resistor marked at 1% tolerance,example 1k ohm + or - 1% should read no less than 990 ohms and no more than 1010 ohms. Anything else your asking for trouble. Another point is that some amplifiers use matching pairs. Pairs complement each other in an output stage and must be replaced in pairs. I repaired a Sansui Amplifier a while back and it looked as if a power output resistor was burned. Comparing the two channels I figured the matching value from the other side and replaced all of them and the system has worked flawlessly for years now. I am a retired electrical engineer and have worked in a few areas of electronics for over 35 years. Hope this information helps you.
May 06, 2009 | Teac A-1D 2-Channel Amplifier
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Dec 17, 2008 | Sony LBT-LX50 CD Shelf System
Just a resistor?
R842 is off of pin 18 of IC804 which controls the red convrgence yoke. I would recomend changing both STK392-110 Ics as well as checking the other resistors R842 is a 2.2 ohm 1 watt metal film resistor. let me know if you need more assistance.
May 30, 2008 | JVC AV-56WP74 56" Rear Projection...
PROTECT PUSH POWER IT KEEP SAYING WHAT TO DO
My Sony audio set keeps saying push power protect and the set freezes what should i do? Please help me solve this problem.
Apr 20, 2008 | Sony LBT-XGR6 CD Shelf System
Phillips 60pw9363 Which IC is red and which is blue
Thats the DPTV 335 series chassis when the IC blows it will usually take out 1 or 2 6.8 ohm resistors along with it. Look at the resistors right next to the ICs you will notice 1 or 2 with a little discoloration in the middle replace those and your set should be back to working just fine. Let me know if you need more help. These resistors are easy to spoy they all look alike and shouldnt have any bands on them they will be stamped 6R8 ohm 1W J
Apr 12, 2008 | Televison & Video
RESISTORS
the baby blue ones with the lines Blue,Gray, Gold ,and gold are the 6.8 ohm resistors the other resistors with the lines blue,orange,brown and gold are 630 ohm , Yes if those resistors are open even one of them the set will not converge. A digital ohm meter is more accurate, but you have to remove one side of the resistor to check them and if theyre open they wont read anything. If you leave them in circuit even a open resistor can measure good due to the resistance in the circuit. Removing 1 leg out of circuit then checking will spot an open resistor quickly.
Apr 04, 2008 | Philips 55PP9352 55" Projection Television
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
