Question about JVC GR-DVL310 Mini DV Digital Camcorder
JVC GR-DVL310 minDV camera plays with Red stripes or bars accross video..
I cleaned the head with a Q-TIP with alcohol since I was losing sound and picture quality on an old tape..Now all my tapes as well as new recordings play back with wide red bars accross the screen..any ideas?
thanks,
Tom
tomthur@aol.com
  • 7 more comments
  • tomthur Jul 30, 2008
    I tried cleaning the head again and the bars are now Blue instead of red..
    tom
    Not sure what a Shamy cloth is but used a Panasonic MiniDV Dv head cleaner to no avail..hard to reach the head..you mean rub some lint free cloth around the head?
    tom
    tomthur@aol.com
    Not sure what a chamos stick is..my head cleaning tape didn't work..hard to reach the head..other ways to clean the qtip lint out of the head?
    I want to be sure people know this is a Mini DV cassette video Camera..and I wonder if head replacement is necessary or if I need to try a "Chamos stick" ? How much should head replacement cost? Is it worth it?
    Tom
    Would a local repair shop be the place for such an elaborate mechanism. Do you think the head was damaged by the Qtip or the alcohol or likely some other part of the mechanism?
    Tom
    A local workshop for "tape pathing" or mail it in? Did you say use a business card to try to rotate the head past it to clean it?
    tom
    I'm trying to figure out if it's fixable at home with a "CHamos Stick" or "tape pathing" cleaning? Or if I need to replace the head?
    Should it be a local shop?
    Tom
    re: "You should use a real tape cleaner on a casette so that the whole tape path gets cleaned. Especially the rubber take up rollers."
    I did use a panasonic miniDv head cleaner tape..I assume this is what you mean but still getting red bars accross my video..do i need a new head, is it worth fixing or should I get a new camera?
    Thanks Dan,
    You think a local shop near San Francisco could actually fix thins problem or do I need to send the camera away? To who?
    thanks,
    Tom
  • 2,071 Answers
This is a hardware problem,is need to clean the circuit board and reheat or resoldering work's,so it will back to normal again.It better you bring it to JVC service center for hardware works..
hope this may help;
Regards,
VOTIT
Posted on Jul 30, 2008
  • 4,234 Answers
As a camera tech, I can say that using the "Q-tip" was the worse thing you could do. As Robotek said. these heads are extremely fragile. In all likelyhood, you have damaged one of the read heads or completely clogged it up. If the tape does not pass over the heads in the correct fashion, the tape won't be read correctly. Since this is a digital recording, the digital dropout can show up as you describe. At this point, you need to get this professionally cleaned and aligned. The pinch roller is not an issue here and a cleaning tape has no effect on it.
Please keep us posted.
Thanks,
Dan
  • ABRsvcs Jul 30, 2008
    Unfortunately, JVC is particular about service manuals etc. Look for an authorized JVC service center close by. That is your best bet.
    Dan
    If the information provided resolves your problem, I would appreciate a rating that reflects it as that is the only way we get feedback for our efforts.
    Thanks,
    Dan
    Master:
  • 763 Answers
Almost all of the tapeheads are cleanable with any cloth soft and some some liquid cleaning or try to buy tape cleaner the one that has a liquid filled on the tape like. hope that helps!
CHARCOIS
  • Charris Suaybaguio
    Charris Suaybaguio Jul 30, 2008
    if you cant buy that cleaner then try to buy a new dv tape. just run it to your player until it finish to remove some dirt on the tapehead.
  • 2,794 Answers
  • 790 Answers
Hi
I suggest to you to bring your unit in electronics shop or go to this links that can help you! Click here
  • 161 Answers
Alcohol can be too harsh on the head of your cam, probably seeped into further inside the cam and caused the problem. I suggest you bring it to a repair shop before attempting to do anything that could cause further damage to you cam. Hope this helps.
    Genius:
  • 2,035 Answers
The head may be damaged in the process of the cleaning which is leading to this problem , try to use a head cleaner cassette for the player , if this did not help then you need to replace the head of the camera :::
Please use this link to replace the head..
http://www.advancecamera.com/repair/
http://www.precisioncamera.com/
Good luck...
  • 1,512 Answers
Hi there
You should never use a q tip for headcleaning. It can damage the head. You should try to use chamois whipe of a plain business card to rotate the ehad paste. the heads are ferrite and very fragile/brittle
robotek
  • Graeme Ross
    Graeme Ross Jul 30, 2008
    Cleaning the heads on the rotating drum assembly can be a finicky job on a cam corder. I suggest trying a head cleaner caassette first and if that does not fix the problem, take the camera in to a workshop for the tape pathg to be cleaned by a pro. Should cost you a little more than min charge.
    Habit-Forming:
  • 35 Answers
You probably got a piece of q-tip stuck in the video head. try to run a chamos stick over the small pickups at the base of the drum from side to side, never up and down and you should be able to clean out the residue and fix your problem.
I have bad audio static when playing my mini dv tapes on two JVC MIni DC Video cameras model GR-D244U and GR-D370U,need help?
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
Sep 07, 2016 | JVC GR Video Cameras
The picture just stopped working, as did the
I had a problem like this with another mini-DV camera (Canon GL1) and I took care of the problem.My first thought is to use a head cleaner tape (dry head). It sounds like you have a dirty video head. DON'T try to use anything else, don't stick anything into the head or tape area. No liquids like alcohol with a q-tip, din't stick you finger in there (oils) and NO METAL. You don't want to scratch the head, even a q-tip, Kleenex, plastic, wood, cotton, t-shirt will scratch the head (and lenses). If this doesn't work, you may need to have it cleaned in a shop. Good Luck!
Dec 28, 2009 | JVC GR-D870 Mini DV Camcorder
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-DVL310 VISTA DRIVER
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310U
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310UM
Jan 20, 2008 | JVC GR-DVL310 Mini DV Digital Camcorder
Black or blank screen
your older recordings will only play on a pal monitor / tv ; if the camera video is ok now ? your tape heads may be dirty , wearing out - or both ; try a cleaning tape first but - do not rewind cleaning cassettes , or the old grime will be put back on the cleaned heads and guides ;
Jul 23, 2007 | JVC GR-D73A Digital Camcorder (PAL System)
JVC GR-D250 does not record properly
When playing the tape in the camera itself, do you hear sound? If so, its something with the connection cable... is not, you will need a professional repair, you can do nothing except the head clean which you did? Sorry.
Nov 23, 2005 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-DVL310 Mini DV Digital Camcorder Logo
151 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
