Question about Maytag Washing Machines
Need to know about warranty information on Crosley Washer.
  • 135 Answers
All parts and labor are covered for the first year.
Posted on Jul 30, 2008
How do I access the drain pump on a crosley front load washer model number cfw4700lwo
Thank you for your post, derek dion!
From the information you have provided you need to know how to access the drain pump on your Crosley washer. I was unable to locate a step by step instruction sheet on how to access the drain pump. From your parts manual you would need to remove the front panel and it is located directly under the drum. If you are having trouble locating it or removing the front panel I would recommend contacting a professional technician for proper disassembly and repair. Best of luck! -OOS
Feb 22, 2015 | Crosley Washing Machines
I have a crosley cawc529pq washer that washes but
Hello friend, thanks for your post!
Based off the information you have provided your Crosley washer is not spinning. I would check to assure that the drain hose is not restricted or kinked. Anything blocking the hose from draining properly will cause your washer to not spin.
If these hose checks out to be fine, I would suggest a potential issue with the motor or control panel of your washer. If parts are needed to be replaced I would recommend you speak with a professional for further diagnosis and repair. I hope this information has been helpful. -Matt
Oct 18, 2014 | Washing Machines
I HAVE A CROSLEY FRONT LOAD WASHER AND THE DOOR WONT UNLOCK, I HAVE TOWELS INSIDE, HAVE TRIED RUNNING ANOTHER CYCLE, PLEASE HELP
I have had that happen a couple of times and by hitting the pause or cancel button a couple of times it then opened.
Mar 05, 2014 | Crosley CW6000 Front Load Washer
Need a service manual for
Hello Colleen, I am happy to assist you!
I see that you are interested in locating a service manual for your Crosley washer, CFW4500KW0. This type of data is very rare to find, however I successfully found the Owner's Guide, Installation Instructions and Parts Manual. Hopefully you find all the information that you are looking for. Best regards!
Frigidaire Manual Search Results
Jan 24, 2014 | Crosley Washing Machines
Apartment size washer dryer. I have the chance to
Formed in 1976 in Winston-Salem, NC, the Crosley Corporation consists of a group of independently owned distributors who resurrected the Crosley trade name and introduced a line of refrigerators, freezers, ranges, dishwashers, air conditioners, and other appliances. We carried the heritage of such features as "Shelvador" and "Conservator" that were marketed for decades.
Sep 27, 2013 | Crosley Dryers
Troubleshooting crosley dryer thermal fuse
Hello - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install/remove for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Dec 09, 2012 | Crosley CDE6000 Electric Dryer
Crosley washing machine codes
Hello protocolu898 - Do you want to know how to display an error code on the washer? Or do you have an error code do you need assistance with?
Nov 26, 2012 | Crosley CW6000 Front Load Washer
Crosley heavy duty washer model cw9500w how do you get the drum off
Hi pucke4488 - Typically this (not a do it yourself job) is something that you want a certified professional to install for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem. Consider contacting your manufacturer for more details on who in your area can properly install this part.
Sep 25, 2012 | Crosley Washing Machines
Drain hose to crosley washing machine, where?
looking at the rear of the washer, my Crosley drain is on the left, about 4" from the floor and about 6" from the side. You might need to remove the back panel. Probably should anyway, so you can blow the dust/lint out of it
May 26, 2009 | Crosley Washing Machines
Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Apr 02, 2009 | Crosley CW5000 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
