Question about Car Audio & Video
No sound from my jensen vm9312
I just had a technician install this unit in my vehicle and everything on the unit works perfectly except for the sound. Is there a reason for this, and is this something that can be fixed without having a warranty?
  • 132 Answers
What vehicle?
Posted on Jul 30, 2008
After 20 yrs of perfect operation, my hotpoint side-by-side is leaking water outside the unit in front. noting is defrosting.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You have ice buildup on the bottom of your freezer. Two things will cause this:
1.) A frozen drain. This is common. You unit goes through a defrost cycle every 8-10 hours for 20-30 minutes. Everything shuts down except for the lights. You defrost heater is turned on. If your drain is frozen the condensate has no where to go except for the bottom of the freeze.
2.) A restriction in your refrigerant seal system capillary tube or you have a refrigerant leak. If you have a block of ice build up in the upper right hand corner of you freezer evaporator (Cooling) coil, then you have a major problem. You are probably looking a $450.00 + repair.
You will have to remove the freezer back wall cover to determine which situation you have.
Dec 07, 2014 | Hotpoint Refrigerators
I had a virus. had my computer cleaned. everything works perfect. except no sound from my speakers. they are connected and not muted. help
Make sure the computer volume itself isn't muted and is not set really low. Check to see you actually have sound drivers installed and the right output selected.
Jun 10, 2011 | Microsoft Windows Vista Ultimate Edition
I installed in my vehicle this head unit and everything seemed to work fine intially. Howevver, when I put the car back together and went back to setup the bluetooth feature for my phone, the entire...
Sounds like it could be a setup issue (software) inside the stereo itself. Maybe try and check out if the manual says any thing about the issue, if not im sure your local stereo installers could help you out.
Mar 01, 2011 | Car Audio & Video
Viper Remote Start wont work properly
if it cranks and wont start then its probably the bypass the module thats not working correctly
May 28, 2010 | Remote Start System
How to hook up Jensens Vm 9312 car stereo indash
how do you make the navigation work on the jensen VM9312
Jensen VM9312
Feb 04, 2010 | Jensen's VM9312 Car DVD Player
Humming sound from the washer
Sounds like the pump is locked up for some reason could be something stuck in it,I have pulled a lot of nickels out those for some reason, they are the perfect size to get down into the pump and get stuck.
Sep 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
Jensen VM9312 Installation
Are you saying you need a replacement face plate for this model ?
Jul 13, 2009 | Car Audio & Video
Car Audio & Video Logo
173 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
