Question about Maytag Atlantis MDE7400AY Electric Dryer
MAYTAG DRYER ELECTRICAL CONNECTION
I JUST BOUGHT THE MDE7400AYQ DRYER AND IT HAS A 3 WIRE PLUG AND ON MY WALL I HAVE A 4 WIRE PLUG. WHAT CAN I DO, I ALSO HAVE A 4 WIRE CORD
  • trekrider58 Aug 24, 2008
    What color wire goes where on the dryer when changing from a 3 wire plug to a 4 wire plug? Thanks
  • Anonymous Oct 12, 2008
    How do I put on new 3 wire/ plug?
How do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Posted on Apr 28, 2010
I jus bought a MAYTAG DRYER that has 4 wire but the plug socket on the wall is for a 3 wire thingy? i live in an apartment complex that hasnt been upgraded obviously, what should or can i do
Posted on Dec 05, 2009
I need a diagram of where the 5 wires connect inside
  • 135 Answers
Remove the 3 wire plug and install the 4 wire one. The connections are the same. Connect the extra green wire to any screw connected to the cabinet.
Posted on Jul 30, 2008
Trying to change plug from a 3pronge hookup to a 4.The dryer only has 3 wires to hook up extenstion plug has white,red,black,green ...what do i do
It is your responsibility
 To contact a qualified electrical installer.
 To be sure that the electrical connection is adequate and in
conformance with the National Electrical Code, ANSI/NFPA
70-latest edition and all local codes and ordinances.
The National Electric Code requires a 4-wire supply
connection for homes built after 1996, dryer circuits involved
in remodeling after 1996, and all mobile home installations.
A copy of the above code standards can be obtained from:
National Fire Protection Association, One Batterymarch Park,
Quincy, MA 02269.
 To supply the required 3 or 4 wire, single phase, 120/240 volt,
60 Hz., AC only electrical supply (or 3 or 4 wire, 120/208 volt
electrical supply, if specified on the serial/rating plate) on a
separate 30-amp circuit, fused on both sides of the line. A
time-delay fuse or circuit breaker is recommended. Connect
to an individual branch circuit. Do not have a fuse in the
neutral or grounding circuit.
 Do not use an extension cord.
 If codes permit and a separate ground wire is used, it is
recommended that a qualified electrician determine that the
ground path is adequate.
Electrical Connection
To properly install your dryer, you must determine the type of
electrical connection you will be using and follow the instructions
provided for it here.
 If local codes do not permit the connection of a neutral ground
wire to the neutral wire, see "Optional 3-wire connection"
section.
 This dryer is manufactured ready to install with a 3-wire
electrical supply connection. The neutral ground wire is
permanently connected to the neutral conductor (white wire)
within the dryer. If the dryer is installed with a 4-wire electrical
supply connection, the neutral ground wire must be removed
from the external ground conductor screw (green screw), and
secured under the neutral terminal (center or white wire) of the
terminal block. When the neutral ground wire is secured under
the neutral terminal (center or white wire) of the terminal block,
the dryer cabinet is isolated from the neutral conductor.
 A 4-wire power supply connection must be used when the
appliance is installed in a location where grounding through
the neutral conductor is prohibited. Grounding through the
neutral is prohibited for (1) new branch-circuit installations,
(2) mobile homes, (3) recreational vehicles, and (4) areas
where local codes prohibit grounding through the neutral
conductors.
Sep 23, 2011 | Estate EED4100SQ Electric Dryer
We have s maytag mdet336aym. The power cord plug does not fit our wall outlet. A person at Lowe's said we could use our old one. It has four wires: green, white, black and red from a whirlpool maybe 15...
As I understand you, you have a 4-wire receptacle in the wall and have just acquired a used dryer, that has an older, 3-wire cord attached. You need to change the dryer cord to connect to the existing 4-wire receptacle in the wall. (Dryers sold new, retail do not come with a cord attached so I assume that this must be a used dryer with an existing cord).
If this dryer has a 3-wire cord attached, it MUST be replaced with a newer 4-wire cord, per the National Electrical Code, as you have a 4-wire receptacle. (However I see no reason that you could not use your existing 4-wire cord from your soon-to-be-replaced dryer, if it's still in good shape).
In older dryers, wired with an existing 3-wire cord, there is usually a metal link provided between the center lug (the neutral lug) and a ground connection on the metal chassis. If it's present, this link MUST BE REMOVED WHEN CONNECTING A 4-WIRE CORD. This is very, very, very important.
The reason is, under a fault condition, current could be carried by the neutral conductor (in a 220-volt circuit, the white wire carries the neutral or unbalanced current. There is no neutral in a 120-volt circuit, even though some people think there is).
The presence of this current can be shunted onto the metal frame of the dryer, making it hot to earth ground (until the circuit breaker pops) and providing a possible shock hazard to a person touching the dryer). Removing this link, removes this potential hazard.
When wiring a 4-wire cord, the white wire in connected to the center lug, the two black conductors (could be a black and a red) are connected to either of the lugs on either side of the center lug, and the green conductor is connected to the metal cabinet. (Once you have the metal junction box cover removed from the dryer, you will see a screw driven into the metal cabinet provided to connect the green wire).
Again, when using a 4-wire cord, there must be no connection between the metal cabinet and the neutral connection through the use of a metal link. It must be removed and discarded.
Feb 09, 2018 | Maytag Dryers
I have a maytag dryer is 1999 model which was connected straight to wall.The wire are inside a coil,there are red ,white and blue. Problem is i whant to change outlet from 3 holes to 4 holes.First I...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2010 | Maytag Dryers
Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Feb 23, 2009 | Dryers
If the dryer has a 4 wire cord and you need a 3 wire cord, you should have a jumper, or little metal strip, that came with the dryer. You will connect this jumper between the green ground screw that attaches to the frame and the screw where you white neutral wire lands on the terminal block.
If the dryer is 4 wire and you need it four wire, you simply connect the white to the neutral screw, the black to one of your hot screws, the red to your other hot screw and you green to the green screw connected to your frame. If there is a piece of metal, "jumper" connected from the neutral or white screw and the green screw in the frame you will need to remove this.
Write back if you need clarification.
MAKE SURE THE CIRCUIT IS OFF AND THE CORD UNPLUGGED FROM THE OUTLET BEFORE STARTING. TEST FOR VOLTAGE BEFORE DOING ANYTHING.
Feb 14, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
My dryer plug is 4 and the electrical plug in the wall is 3
There is no "adapter" per se, you MAY be able to swap to a 3-wire cord, however that may be against local code. The only other option in that case would be to have a qualified electrician install the newer 4-wire outlet. You need to find out what you local codes are with regard to this issue. If you do change to a 3-wire cord to macth that outlet, it is critical that it be installed correctly.
Dec 14, 2008 | GE DSXH43EAWW Electric Dryer
Conveyor dryer wiring
Newer electrical codes call for a 4 wire receptacle. never splice appliance cords, it isn't woth the safety issue and they are not very expensive. you need to access the terminal block, which is where the cord goes into the dryer. the cord you use (3 or 4 wire) will depend on what is on your wall. if you wall has a 3 wire plug then you will need to connect the green wire from the center terminal to the frame of the dryer. there is probably a hole and screw next to terminal block. that is where the green wire goes on a 3 wire hook-up. if you have a 4 wire receptacle then the green wire should be hooked to center terminal (white). you will have to obtain the proper cord (pigtail) from a parts supplier.
J
Jun 10, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,303 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
