Can you show me step by step procedures for electrical troubleshooting of a commercial rooftop unit. trane or carrier. preferably the control stde after the primary side. i'm having trouble with different types of switches and relays,--testing procedures
    Problem Solver:
  • 7 Answers
This is not the appropriate forum for free schooling. You need to have a technician teach you in person in a hands on manner.
thanks,
clean up crew
Posted on Jul 30, 2008
Where I can get model numbers? For my Old Trane rooftop gas fired units, model# not readable.
Take pi's to local supply house, most who have earned their salt can have a look and ID
Feb 11, 2015 | Heating & Cooling
The outside fan in my carrier unit will not stop running when temp inside has been reached?
There can be multiple problems with your situation, one being a stuck condenser fan motor contactor/relay, a shorted motor, bad control board, etc. If you could at least check the contactor that controls the CFM and see if it is pulled in that could help narrow down the search for the answer.
Sep 23, 2011 | Carrier 50TJ028 Rooftop Electric Cool Air...
What is the age of the following Carrier RTU - Model # YCDO6OC460BF & Serial # R28105287D I have been told 1982, 2000 & 2007. The unit does not look that old, so do not believe it was a 1982,...
YCD060 is a Trane unit number not a carrier. Trane has a large guide for looking up approximate age of equipment. There is no date coded in the serial number, Trane does include a mfg date on most of the labels on later equipment, look for it on top or bottom corner of label if you can still read it otherwise I have the cuide at the office and will look it up this week. FYI our company is a TCS Trane dealer.
Aug 24, 2011 | Heating & Cooling
I had a power surge on my 15 year old HVAC residential Trane Unit. I can either have my insurance repair it or I can pay the difference to replace. I do have coverage to pay for Alabama state building...
13 seer minimum for new installs. I have seen ratings as high as 18 or more on
some units (410A systems)
I recently replaced my system with a 13 seer R22 system, since they are
more easily serviced and I am very familiar with them. Given the average lifespan of
a system before major service is around 10 years depending on model.
I have worked on Trane, Carrier, Intertherm and Goodman units and prefer the Goodman
units, as they seem to be much quieter running and are built in America.
Jul 15, 2011 | Heating & Cooling
Don't have a manual, just need to know how to change ink and toner cartridges:)
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    If i am in the process of buying a generator to run 2 carrier RV rooftop ac units how big should the generator be?
    You need to find out the maxamps of the rooftops which is located on each unit, then you will need to find out if these are 1phase, 2phase or 3phase units.
    That information is also located on the unit and usually is marked 1P or 2P or 3P. If its 3Phase you
    would need to talk to a electrical contractor or the
    manufactuer of the generator you wish to purchace.
    More in for is needed on the phase of the unit and amps that it draws
    Feb 12, 2010 | Dometic Rooftop RV Air Conditioner
    One of my customers had a goodman vsc060 compressor installed and I wanted to know if that is used in commercial also and how reputable of a unit it is compared to trane or other well known names.( His...
    Goodman is are decent (builders grade) equipment. Not as good as Trane or Carrier but if it's installed correctly it should be fine. Goodman is mainly a residential brand but they do make some light commercial equipment which again is decent as long as it is put in correctly.
    Mike
    Jul 09, 2009 | Heating & Cooling
    My rooftop Trane A/C unit shows high humidity on the thermostat, will not cool the house during the day but cools fine at night. What could the problem be? Also, how can I lower the humidity in the house?
    High humidity causes Icing of the cooling coils. Avoid constant running of the a/c. Meaning let the AC pull the house dow 2 - 3 degrees at a time.. The unit shutting off will allow the ice to melt. Make sure the drain is clear by going outside and chkg for drainage. Once the house is reasonably dehumidified the ac can be set and left on its own.
    Jul 06, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
    No heating, cooling or fan.
    I'm confused. You have a Trane, but are asking about the Goodman warranty. I missed something there I'm sure, sorry.
    "IF" Trane has a recall or warranty issue, then any qualified technician should be able to help you with that. The parts would be provided by trane in such an event, but unless the unit is less than 1 year old, chances are you will have to pay for the labor.
    Being an electricain help if you want us to assist you in troubleshooting.
    This link takes you to the TRANE contact page. They can answer any warranty/recall questions you have.
    Jan 21, 2009 | Heating & Cooling
    Error 1203 Lexmark F4270
    The 1203 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. The procedures in this article will help you to resolve this issue.
    Troubleshooting a Communication Error between the Cartridge and the Printer
    Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
    Did the error message return?
    Yes: Continue to step 2.
    No: Print a test page. If the test page prints, the error is resolved.
    2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
    Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
    No: Continue to Step 4.
    4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
    Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
    No: Continue to step 6.
    6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
    Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
    NOTE: The embedded links in the table lead to specific troubleshooting documents.
    Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
    click here for instructions).
    Dec 16, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    Heating & Cooling Logo
    96 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
