Question about Whirlpool Calypso GVW9959K Top Load Washer
Lights,tries to run
We are trying to do a load and water trickles in for 10 seconds and then stops. Sometimes it tries to spin.,sometimes it just sits there. We have been hitting the stop/cancel button before opening the lid. This has been a lemon since the beginning.
  • 135 Answers
Sounds like you have a bad control board but could also be a pressure switch problem. You would have to have a technician check it out. The calypso machines were discontinued after a class action law suit. They have multiple issues and are not worth repairing. Save your money and buy a new machine.
Posted on Jul 30, 2008
My LG top load washer keeps stopping mid cycle- what could be wrong?
First rule out the simple points like to clean the filter for fluff or coins that may be interfering with pump. Secondly is the pump itself.
Jan 09, 2018 | LG Washing Machines
Machine gets stuck between rinse ans spin and sits for a while then spins but wont stop, then **** from the in the machine or hose is on the clothes???? Any suggestions? Machine is a top loader smart drive...
You could try a hot load with epsom salts....this will clean out the machine....Make sure it is with hot water. It goes slow in between rinse and spin possibly because it is slow draining...clean out the pump. Also as it FILLS make sure the water runs in properly and not just trickle in making a hissing noise. Good luck. Tony the technician.
Apr 02, 2011 | Fisher and Paykel Washing Machines
I have a problem with my MW512AU. Sometimes it drains after wash cycle, sometimes it doesn't. Sometimes the drain pump stays on when it goes through spin, but spin doesn't get up to fast speed. When it...
Hi just read your posting.This problem sounds like your control module is doing funny things.Does it show an error code at all and beep?What part of Australia are you in?There is a place in Melbourne that tests these modules.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
2007 Vue hybrid. 12-volt battery dead? No electric key opening, lights, starting, etc. Can I try to trickle charge it? We;ve been away a week, but it has been sitting in a garage above 50 degrees.
If the battery is completely dead a trickle charge won't do much. These are designed to keep a good battery good. You need a regular battery charger set to 10 amps for a couple hours then 2 amps overnight. Be aware that sometimes if your battery has been completely killed it may not work for long, that is your car will start but within a few days or hours it will leave you stranded. You'll know because it will drag when you try to start it. Sometimes you get lucky and it works great for years.
Next time do use a trickle charger! Also if the charge you use is automatic then you can leave it hooked up in 2 amp mode when you are gone. Good luck!
Mar 26, 2010 | Saturn Vue Hybrid Cars & Trucks
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Will not spin when clothes are in the washer
Hope this is not a double reply, I'm having problems with this board. You have the symptoms of a Clutch issue if the machine type is a FAV6800AW or FAV9800AW. If that is your machine type please see this Post if you want to DIY the fix or share with a repair person. Post back if you have questions
Aug 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The cycle stops after agitating for about 10 minutes and just sits in water--it doesn't complete the spin cycle no matter how long I let the washer sit.
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it using the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down . Have to replace the lid switch for it to work properly or bypass the lid switch from under the console .
Aug 17, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
