Question about Samsung TXR3079 TV
Quick question...if there is such a thing
I have a samsung txr3079 tv. when i plug it in i can hear things power up, the red light next to the power button comes on, but the tv will not turn on and there is no sound. does this sound like something that is worth getting checked out or is my tv destined to make its way to the trash?
  • 1 more comment
  • Anonymous Sep 04, 2008
    same here, same prob. Red light blinks but tv/screen remains in black.
  • Anonymous Nov 08, 2008
    yeah my tv shut off on its own and now will not power up sound or picture only the red light blinks on front and according to the site justanswer.com they told me for a $9 charge that it is most likely a capacitor or power supply issue and will likely cost $200-$300 to repair. its only 2.5 years old and i will not buy SAMSUNG again.
  • matthewtyl Nov 18, 2008
    I am also having the same issue where there is no picture or sound, but the red light blinks when I attempt to use the remote.  I too have had it for just over two years.  I was never happy with the picture quality; the black bars on the sides were never straight and the outer thirds of the screen is less than crisp when I playing full-screen high-def channels and movies.  This was the worst purchase I have ever made.  I should have spent the extra couple of hundred dollars to go lcd or plasma, but I cheaped out and I am now paying for it.  If the fuse trick does not work, I will be looking for an electronics recycler in the area since a $300 dollar repair can't be justified on a TV that was $800 over two years ago.
    Problem Solver:
  • 7 Answers
Esullivan:
I had the same problem with my Samsung TV Model: TXR3079WHX. I troubleshot my problem with a can of component cooler from Radio Shack and found my problem to be a defective voltage regulator, identified as "QR015" on the main circuit board (the same board that contains the high voltage section).
Caution:
Before I proceed any further I need to strongly warn you. Do not attempt to remove the back cover, troubleshoot, repair or perform the actions that I have done, if you are not a "qualified service technician". Removing the back cover exposes you (and anyone else) to harmful and deadly electric shock, even though the TV may be unplugged from the wall outlet and turned off. You (or anyone else) can be seriously injured or even killed. If you are not qualified, play it safe by allowing others who are qualified repair this for you.
The defective part (overheats and shuts your TV off) is voltage regulator manufactured by Fairchild. The part number is KA75450ZTA. This part is available from Mouser Electronics for less than 20 cents plus shipping. In order to replace this part a qualified technician will need to remove certain cables and unscrew the main board to allow access to desolder and solder the new component.
Hope this helps.
Posted on Jun 06, 2009
You need to replace the HOT, FJL6920.
Posted on Nov 26, 2008
Did you get an answer about whether to pay to get it fixed? I replaced the fuse and it didn't work.
Posted on Sep 29, 2008
Try this site.  They may be able to help you. (Sorry it is on 2 lines) http://www.samsung.com/us /support/repaironline/supportOnlineServiceRequest.do The code should be: TX-R3079WH
LOVE my CRT!
Shelleyfofelly
Posted on Aug 03, 2008
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
My Samsung HdTv will not come back on. Only a small red light next to the power button is blinking. First it was blinking six times then five now six again. Model TXR3079 or 8WHKXXAA. Samsung hdtv...
Hello, You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If you need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where. power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem
Aug 27, 2011 | Samsung Televison & Video
My Sony TV Model # KP-51WS510 flushing 4 red light or blinking 4 red light again and again, once I turn on the TV power. No picture on the screen and you will hear that it will shut off but the 4 blinking...
Usually a flashing power light on a rear projection TV means a bad bulb, try replacing the bulb. Also try unplugging it for 10-15 minutes, then come back and plug it in and try again. Also if its been a long time since its been serviced it could be dust buildup causing overheating, do you hear the cooling fan running? It could also be a failed cooling fan. Generally the first thing i do with projection TV's is clean them, clean all the vents, pull the bulb out, clean out the cooling fan and bulb housing, and then try a new bulb. If that doesn't fix it then its a bigger internal problem and there is no quick fix but have it serviced.
Jan 02, 2018 | Sony KP-51WS510 51" Rear Projection...
When i hook ps3 to tv the power will come thru but no picture
First thing to try is a soft video reset.
While the PS3 is off (solid red light), hold down the POWER BUTTON until you hear the SECOND BEEP, quickly release.
Let me know what happens.
Oct 13, 2010 | Sony PlayStation® 3 (60 GB) Console
Cant see anything on tv
First thing to try is a manual video reset:
While the PS3 is off (solid red light), Hold Down the power button until you hear the SECOND BEEP, quickly release.
Let me know if this solves your problem.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Ps3 tv screen just keeps blinking?
First thing to try is a video reset.
While the PS3 is off (red solid light) hold down the power button until you hear the SECOND beep, quickly release the power button.
Wont Power up
jwx41600:
I had the same problem with my Samsung TV Model: TXR3079WHX. However, I was able to repair my set while it was still intermittant (would turn off by itself after 30 minutes of operating, would have to wait 5 minutes before it would turn on again).
Caution:
Hope this helps.
Sep 24, 2008 | Samsung TXR3079 TV
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Samsung TXR3079 TV Logo
324 people viewed this question
Henry  Thomas
Henry Thomas
