Thermostat transformer 3amp fuse blows on carrier weathermaker 8000
I have the same problem with my Goodman compressor. I removed the relay so the wires that control the relay on the compressor are open circuit. They are, and the fuse no longer blows. There must be something wrong with the relay. The resistance on the 24 volt coil seems a little low, but it is not a dead short. I thought the wires might be shorted, but removing the relay would not have fixed the blowing fuse if that was the problem.
Posted on Jul 10, 2010
My Carrier Weathermaker 8000 is blowing air out of the air intake. Is there a fix?
Try turning breaker off and back on. Fan is running backwards. Any recent repairs?
Nov 05, 2016 | Carrier Heating & Cooling
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Thermostat doesn't activate unit
Put a volt meter on the red wire and the C terminal. You should get 24 volts AC. If not then the control transformer is shot
Jan 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
3 amp fuse blows when ac is switched on. Heater works fine.
There is a short in the low voltage wires somewhere for sure. The most common place is the low voltage on the outside unit, sometimes animals chew through them or they get cut with a weed eater. Just my experience. You basically have to trace it back all the way to the thermostat and heater. The only other thing is the contactor
Jun 30, 2012 | Carrier 38CKC060 Air Conditioner
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Have a carrier weathermaker 8000 model 58zav need a transformer any ideas of the part no.
Match your transformer up with one of these transformers
There are transformers there for most any application...
Sep 27, 2010 | Heating & Cooling
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
487 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
