Question about Acer Aspire 3610 Notebook
My laptop I have an acer laptop.. The battery is not working for it.. there is this little metal thing inside for the battery plug to go into.. that metal thing got loose and it fell inside the laptop...i took it out and now i lost it.. so i dont know if my laptop is fixable.. please help me and tell me if i can get it fixed and where..thanks
  • Marcum12 Jul 30, 2008
    thank you.
    Another thing.. There is a big crack on the side of the laptop cover.. and My screen wont show and when it does its all fuzzy and red...and sometimes it freezes so i cant use it.. I hooked it up to a regular pc screen and it works fine.. but is the reason why my screen is like that .. is that from the crack?
  • 54 Answers
Yes that can be fixed and it is quite easy. You can just take it to any electronics shop some places might have to send it away but some will fix it right in store. They just need to solder a new connection in for you and takes about 10-15 mins.
Posted on Jul 30, 2008
  • Kevin Arseneau
    Kevin Arseneau Jul 30, 2008
    anytime
  • Kevin Arseneau
    There is a cable that goes from the base to the screen and when it was dropped it may have pinch this cable causing it to not work correctly.
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
The adapter light is on when first plugged in but then when I connect the adapter to my laptop the light goes off and it doesnt supply any power
I suggest check out the AC adapter first.
1) When plugged into power, and plugged into the laptop, gently wiggle the cable from the AC adapter TO laptop.
Any change?
Do the same on the power cord TO AC adapter.
NO?
Go on.
2) The port on the laptop that the plug from the AC adapter plugs into, is the DC Power Jack.
If we are discussing an Acer Aspire 5738Z Notebook PC, the DC Power Jack resembles this one, (Not installed),
http://www.batterysupport.com/acer-aspire-5738-jack-p-302046.html
(When I note the DC Power Jack, it is this link I will be referring to )
As you can see there is a Center Pin. All power removed from the laptop, use a small wooden, or plastic object, and see if this pin moves around.
ANY perceptible movement means a bad DC Power Jack.
DC Power Jack checks out it's back to the AC adapter.
Wanted to perform the easy diagnosis first.
This will require a multimeter. An economical, yet fine for this test multimeter, can be purchased for as little as $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog or digital is fine.
http://www.youtube.com/watch?v=bF3OyQ3HwfU
(Analog is fine. Some of us still like 'em)
DC Voltage is what you are going to check.
Black probe lead (Negative) goes in the Common port on the multimeter. (COM)
Red probe lead (Positive) goes in the Voltage port on the multimeter. (V)
If the multimeter just has symbols around the Function Knob, set it to the dotted line over a solid line, symbol.
The plug on the end of the AC adapter, that plugs into the laptop, has a center hole, and a cylindrical metal shield surrounding it.
The Center Hole of the plug is where the red Positive lead, of the multimeter goes.
The outside cylindrical metal shell is where the black Negative lead of the multimeter goes.
Hold the AC adapter plug in one hand, and at the same time hold the red Positive multimeter probe in the center hole.
With the other hand touch the black Negative lead of the multimeter, to the cylindrical metal shield on the outside of the plug.
You should read 19 Volts (DC), or VERY close to it,
http://www.cellularfactory.com/laptop/ACER/3/305268/
I believe the AC adapter is the problem. Post back in a Comment as to your findings.
Regards,
joecoolvette
Apr 29, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
How to change cmos battery
It's quite simple. First of all you have to turn off your computer and unplug all device cords from the back. Lay the computer facing up on the floor/table. Now, you have to locate the CMOS battery (It's similar to a watch - a little bigger though). It is on the motherboard held on by thin metal tabs. Some computers have the battery flat against the board while others have it in an upright slot. Use your fingernails to remove the CMOS battery and gently lift the metal tab. It is so weak that it can break easily. Do not lift the tab all the way or pull it off. Take the fingernail and place it under the battery in the casing and easily lift it up then pull it out. The last thing you have to do is replacing the panel and plugging in your devices.
I hope it works! Have a nice day!
May 18, 2011 | E-Machines M5105 Notebook
My Acer aspire aoa 150 will not charge. Its not the charger or battery It seems to be that little thing inside the computer that transfers it. Any idea as to how i may be able to fix that?
Hello.
If you wiggle the cable where it connects to the laptop and the power goes on and off, the power jack (inside the laptop) needs repair or replacement.
Hope this helps.
Aug 18, 2010 | Acer Aspire One AOA150-1570 Notebook PC
My new acer laptop only works if pluggd in
u try one thing just shutdown laptop remove battery and charger from laptop then after push power button for 1 minute after that install battery and charger. but not start laptop and check that charging led of laptop is running if it's runnig then put in same condition for 3 to 4 hours after that start laptop using battery only after proper booting when os load attech the charger and check charging status.
Dec 27, 2009 | Acer Aspire One PC Notebook
Laptop Charger will only work is laptop is turned off.
it sounds like the charger does not have sufficient wattage for your machine. i would try getting a certified acer power supply.
Aug 14, 2009 | Umax ActionBook 333T Notebook
I have an acer aspire 3690, and when I plug the power cord in to the laptop, the battery does not charge any more. What is wrong with it?
It one of two things wrong here,
1) have your replace the battery yet?
2) Does your AC cord work properly?
Check that and let me know.
-Charlie S.
Jul 18, 2009 | Acer Aspire 3690-2196 Notebook
Acer aspire 3050 screen flashing.
maybe your video card is going bad. and sooner or later you are going to need one
May 30, 2009 | Acer Aspire 3050-1733 Notebook
Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Apr 09, 2008 | Computers & Internet
Alt key pulled off
Well, it could snap back on, or the little metal springy thing has to be in place first. try gently popping ANOTHER key and seeing how it is held on...
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Acer Aspire 3610 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
