Setting RAA 40 heating control - Heating & Cooling
    Problem Solver:
  • 7 Answers
Please be more vague. I almost have some information from your question.
Posted on Jul 30, 2008
40 year old maytag dryer
You need to replace the temperature control rheostat, which I doubt is available.
Sep 22, 2016 | Maytag Dryers
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
My oven gets warm but will not reach set temperature. Is this the element
Hello Peter;
I recently repaired a oven that would be off as much as 200 degrees. The normal operation of your oven is to rise 20-40 degrees above set temperature and shut down until it drops 20-40 degrees below set temperature, turns back on and repeats the cycle again.
Generally, there are only three components that control your oven temperature:
1.) The Heating Element - If you are getting heat your heating element may be good. To be on the safe side inspect the two connections on the back wall to ensure they are not corroded.
2.) The Thermocouple - There are several different thermocouples depending on your model and if your have gas or electric. These are easily replaced.
3.) Oven Control - Here again there are several different controls, both mechanical or digital.
I just purchased a oven thermocouple and a reconditioned digital control over the internet for under $75.00.
IF YOU HAVE A DITIGAL CONTROL - GROUND YOURSELF BY TOUCHING BARE METAL. STATIC ELECTRICITY WILL KNOCK OUT A BOARD.
So, go into the following website put in your model number and select parts. Several diagrams with part numbers will appear. Your model number is on a metal plate on the face of your oven after you open the door.
Fine your thermocouple and oven control. Copy these part numbers and search the internet for best price.
First, replace the thermocouple. If this solves your problem then return the control for credit if not install the oven control. The highest probably is you have a bad thermocouple
Water Filters Lawn Garden Appliance Parts
May 07, 2015 | Ovens
GCV 40 100 Burner and pilot shuts off when heating up
Get more fresh air to the unit.
Clean the air intake/ flame trap/ flame arrestor located on bottom of tank.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment with type of gas control valve, for possible troubleshoot.
Copy following link to read service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Aug 17, 2012 | A.O. Smith GCV-40 Promax Residential Water...
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
Had the battery changed, but now the (heat) vents in the top of the van and the floor vent (heat) does not work - only cold air comes out. Also, the heating/cooling dial lets it get hot midway on cold...
Try this calibration procedure and let us know if you have more questions:
  1. Start the vehicle.
  2. Wait 40 seconds for the HVAC control module to self-calibrate.
  3. Verify that no DTCs have set as current DTCs.
  4. Clear all DTCs.
  5. Place the ignition switch to the OFF position.
  6. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  7. Rotate the Mode knob fully counterclockwise.
  8. Rotate the Mode knob fully clockwise.
  9. Rotate the Mode knob fully counterclockwise.
  10. Release the AC button.
  11. Wait 40 seconds for the HVAC control module to self-calibrate.
  12. Start the vehicle.
  13. Verify that no DTCs have set as current DTCs.
Nov 14, 2010 | 2005 Pontiac Montana SV6
Heater problem
hello dan, do you have an i-drive in your car. if so take a look at your climate settings and make sure the settings in the i-drive are not set to full cold (4 blue bars). The settings of 4 blue bars can make up to a 40 degree difference in distribution temperature. Just the same if you adjust the bars to 4 red bars.
Mar 18, 2009 | 2007 BMW 525xi Sedan
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
