Question about HP DESKJET PRINTER, HP OR COMPATIBLE
HP deskjet D1430
My printer will not print,load paper or anything.I don't see any paper jams or foreign materials obstructing proper operation.I don't know much about computers.Any help would be greatly appreciated
    New Friend:
  • 159 Answers
Chick ink
Posted on Jul 30, 2008
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Paper jam
Hi Ruth,
This should help you fix the issue.
Remove Jammed Paper
If business card sized paper loaded sideways is jammed:
1. Power the printer off.
2. Open the top cover.
3. Remove the jammed paper with your hands.
Note: Be careful not dirty your hands. Do not use tweezers or other metal instruments to remove the jammed paper or printer damage may occur.
4. Close the top cover and power on the printer
5. Load the papr correctly in portrait orientation to resume printing.
remove foreign objects
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once.
The images below show the iP2200 model.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
Note: Avoid touching inner parts.
4. Power the printer on and confirm that the printer operate normally.
Use a flashlight to find any possible jam.
Regards,Suhail
May 19, 2012 | Canon iP2600 series
My HP Deskjet 3845 printer had a paper jam and it was removed. It still says it has a paper jam and will not print. How do i fix this?
It sounds like your issue is a sensor is still not happy. Several things happen, but Long story short, you need to get REALLY GOOD LIGHT, get the printer on a table where you can work on it.....
So you need to inspect the entire paper path for foreign material, like torn paper. the sensing typically happens with little plastic levers. These levers get pushed out of position, and force a false indication. any dislodged lever needs to be put back, not necessarily an easy task....
Fortunately, most issues are some teeny tiny tear off of paper, wedged in somewhere.... Inspection and extraction fixes 90% of this issue....
Don't force anything.
Mar 11, 2011 | HP Deskjet 3845 InkJet Printer
My printer is not print it show's paper jam but the paper is not jam
Hello thanks for using Fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any HP service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using Fixya
Feb 25, 2011 | HP DeskJet 3940 InkJet Photo Printer
The printer started jamming and shreading up paper. Now the paper is being pulled through at an angle if at all. When there is no paper going through the printer still seems to be going through the...
The following a step by step instructions for the printer issue:
First Set Prevent paper abrasion (Windows)
By using the Prevent paper abrasion function, the space between the print head and paper is increased, preventing print head contact with the paper.
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer maybe damaged. If there is any foreign material, remove it at once.
Removing paper jam:
If the paper tears and a piece remains inside the printer, open the Top Cover and remove it. If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically.
Paper Loaded in the Cassette Jams inside the Printer
(1) Press the POWER button of the printer to turn off the power. Then, open the Rear Cover.
(2) Fold a piece of A4 or Letter-sized plain paper in four, push it in until it hits the jammed paper, then pull out the paper folded in four.
(3) Close the Rear Cover, then press the POWER button of the printer to turn on the power.
Wait until the jammed paper is automatically ejected.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Sep 11, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
PAPER JAM
hi!
try to reinstall your printer driver and then
clean the roler and check the port of your printer
Sep 11, 2008 | HP Deskjet D2360 InkJet Printer
Pixma iP 1500 shows paper jam and makes squealing noise when activated to print. There was no paper jam when this occured.
Remove foreign objects from the paper path iP1500
Remove foreign objects Foreign material inside the printer can cause printer malfunction Caution: The power cable should be disconnected from the unit when inspecting the paper path for obstructions.
  1. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove it by hand, or with tweezers.
  2. Check to be sure that there is no foreign material by opening the printer's top cover and paper output tray.
Sep 05, 2008 | Office Equipment & Supplies
HP 3820 Deskjet Printer
1) take a flash light and inspect the paper path just to make sure there really is nothing there.
2) print a test page from the printer by pressing the big button ( I think) one of the buttons, can't remember I work on so many models
3) take out cart. turn off then on, install cart. and do step 2
what happens
Jan 04, 2008 | HP DeskJet 3820 InkJet Printer
I have a hp deskjet d1341 printer
take off the back cover of printer and check it out for any paper left from the paper jam and then make sure you replace the back cover properly. : )
Oct 18, 2007 | HP Deskjet D1341 InkJet Printer
Deskjet 3845 not printing properly
it needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
Jun 25, 2007 | HP Deskjet 3845 InkJet Printer
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
