Question about Maytag Atlantis MAV8551 Top Load Washer
Water dripping into tub
Our 5-year old Atlantis MAV8551 top load washer has started to drip water into the tub when washer is not in operation. The faucets are normally left in the open position, turned off now between washings as a precaution. No water is leaking on the outside of the machine. Any ideas?
  • kjkessler1 Sep 12, 2008
    My maytag is a LAT 2500 performa. It also drips water into the tub from the water inlet place when the washer is not in use. Is it the inflow valve?
One of your water solenoid valves are either going bad or stuck open with a little sediment. Find out which is leaking by turning off one of the water lines to the washer. If after it is turned off it still leaks try turning the first water valve back on the turn the other water valve off. This will help you determine which solenoid valve is having the problem. Once identified it is easily replaced.
Posted on Sep 29, 2008
After washer has stopped, it contunes to drip inside the tube
Start the washer in a normal cycle, once it starts to fill, unplug the unit from the wall. If the water stops completely its not a water valve issue. If it still drips, replace the water valve to the washer. Good Luck
Jul 12, 2014 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Water dripping into washing machine tub
Your water inlet valve where the water supply hoses connect is probably leaking because it's not shutting off completely because of sediment in the water line. Replace it or you can try cleaning it.
Oct 26, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Dripping water into tub
seems to me that there is something holding open the valves. you can take the hoses off the back (turn off the water first, naturally) and see if there is a lot of buildup inside the valves. There are screens in there that you could take out to inspect inside the valve from that side, perhaps you can see something there holding it open. If there is nothing you can do, you may have to replace the valves. Not sure of cost but shouldn't be too costly.
Sep 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water built up in Maytag Washer Model MAV-17
I would check the water valves or the water lines. If the water valve is leaking, the water could be running out and following down the cabinet then in to the tub, or the water valve water line that leads right in to the tub there for leaving a water build up.
Mar 01, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water drips into tub when machine is not running
hi. thanks for the question. its strange that after you changed the valve . that its still doing it it .can only be a faulty valve. replace under warranty, in the mean time turn water off .the water should be shut off after every use anyway. we see some flooding from broken hoses, when nobody home. quite the mess .thanks the appliance doc please rate me
Oct 01, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Roaring washer
This is probably a part of the tank water seal. There is a bearing in there also. Does it leak water from that area? Usually the seal goes bad and it starts to drip water down into the bearing below, which starts to rust and then starts to make noise. If you can locate the bearing, you might try dripping a small amount of oil into it to see if it changes the sound any.
Nov 17, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Maytag Atlantis MAV8551 Top Load Washer Logo
560 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
