Question about Sony DCR-TRV285E Digital-8 Digital Camcorder
Re-Insert the casette problem
No matter what I try, i keep getting the darn...re-insert the cassette message can you please help me too.
Thanks,
marc I have the same problem. It only developed after using tapes other than the original. The non original tapes were accepted for a while, then for no known reason I keep getting the 'reinsert cassette' message.
When I go back to the original tape I have no problem.
This is a major product fault as the manual says it will accept any standard digital 8 tape.
  • 97 Answers
Sony is notorious for brand specific the same can be said for their mavica series cameras that can use any mini-disc. unfortunately the best solution is to stay with sony tapes
Posted on Jul 30, 2008
When i insert the Sony Cassette i get the message Reinsert the cassette what can i do
there is a caasette called cleaning casette in the the shop itself
oyu can get it from the shop itself
its the same as the cassette
Dec 13, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not rewind
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Sep 28, 2009 | Video Cameras
Will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Mar 28, 2009 | Canon ZR300 Mini DV Digital Camcorder
Reinsert cassette
not a problem recognizing the tape but a problem with the casette mecanism, swtiches. it has to be serviced and cleaned
May 03, 2008 | Sony Hi8 Hi-8 Tape
hey dats d most common problem.. use the original sony dv cassette and u will be okay.. don't use other ones.. such as fujifilm, etc.. i also fixed mine using d same trick.. please rate my solution.
Apr 04, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
133 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
