Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Vane control on Mr. Slim Remote
I can adjust the vertical direction of the vane control to the "downward" postion, directing the flow of cool air from the unit downward, toward the floor. It stays in that position for an hour or two and then returns to the "straight out" position, blowing cold air directly out in an unwanted direction. I then have to turn the unit off, and restart it. Without any resetting on the remote, it then returns to the desired "downward" vane position and contiunes to operate that way for an hour or two before it again reverts to the direct out position which I generally do not want. Can't the desired downward vane position be maintained throughout the operation of the unit? Am I doing something wrong in "programming" the vane control via the remote?
ThANK YOU,
BILL WRIGHT
PUNTA GORDA, FL
  • 1 more comment
  • Tanveer Ahmed May 25, 2009
    i have the same problem can anyone help
  • kyle woodhouse
    kyle woodhouse Aug 19, 2014
    I have the same issue as well. The vane setting will not stay put. I put it on the lowest setting and then an hour later its back to the middle all by itself. Very annoying.
  • Thomas Woodburn
    Thomas Woodburn May 02, 2018
    you could unhook the vanes from the motor, then they would never move but I have never heard of this problem.
I have mr. slim ms c18vc but i dont know how to set the air flow to left-rigt directions. it flows straight only.
Posted on Jul 11, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Posted on May 26, 2009
  • Mohd Glk
    Mohd Glk Apr 30, 2018
    can make a video or send link to do...i just try but still same
How do I adjust the governor
governors on small engines common to used in lawn tractors ,use a fan governor system , there is a cooling fan built into flywheel , as it spins faster it makes more air and this air is directed towards a paddle that's connected to throttle shaft via a spring , this same springs tension is what controls how much force it takes to move the paddle in the air flow , if your engine speed is hunting (up/down) first eliminate any possible carb flow problems (#1 cause) then you can replace spring on paddle shaft as well (they do get fatigued )
Mar 22, 2016 | Garden
Direction of flow air conditioner filter
There are quite a few possible answers to this because you did not specify what type of unit you are asking about: Central Air, Window unit, Stand-alone-upright Unit, etc.
If this is a central-air unit or a unit that uses your furnace blower to circulate air, then in most cases the filter is a square or rectangular shape and is between 1 and 4 inches thick. The "Direction" the air flows through the filter is indicated by a set of arrows printed on the thin edge of the filter - usually with the word "flow" or "Air flow". Insert the filter with the arrow(s) pointing toward the furnace/blower. Another way to determine flow direction is if the filter has a mesh or screen on one side of the filter media. In this case the screen or mesh would go toward the furnace/blower when the filter is inserted.
Sep 13, 2014 | Heating & Cooling
Iv been told that there is a valve that sticks somewhere around the turbo on my A4 tdi could anyone tell me exactly where it is and how to get it out?
If the car goes in "limp mode"!!!
After scan the EDC-15P engine control unit with a VAG or KTS -BOSCH diagnosis tool you will find this: Fault code: P1557-Turbo Boost pressure control exceeded
1. Engine stopped and ignition switch off. Check all pneumatic connections and hoses between turbocharger actuator = pressure unit for boost-pressure control, boost-pressure control solenoid valve, vacuum reservoir, EGR control solenoid valve, intake-manifold flap solenoid valve, EGR valve with throttle - part of intake manifold. Also the vacuum connection between tandem pump and brake booster. If you find something wrong replace parts. If not go to step 2.
The boost-pressure control solenoid valve is placed in front right side of the cylinder block. Follow the rubber vacuum pipe direction, going from the turbocharger actuator toward the boost-pressure control solenoid valve.
2. Extract the hose of the turbocharger actuator = pressure unit for boost-pressure control part of turbocharger. Instead of the original hose you must place another 1 meter long hose with the same inside diameter, and then you check to inspire yourself the air from the other one extremity of this hose. The mechanical connecting rod of the turbocharger actuator must have a smooth and whole motion. If you can do that with your mouth, then you must replace the boost-pressure control solenoid valve. If you can not reach this with your mouth, then you go to step 3.
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increase too much and ECU (engine control unit) go in "limp mode" = engine protection software. As a result the "limp mode" engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault still remain in ECU memory!
4. You must be able to extract the turbo from the engine and then to disassemble the turbocharger, clean inside adjustable vanes mechanism and refit all.
Dec 07, 2010 | 2000 Audi A4
Replacing heater core in a 1995 Toyota 4Runner
The heater core is a small heat exchanger located inside the truck, similar to the radiator at the front of the truck. Coolant is circulated from the engine through the heater core and back to the engine. The heater fan blows fresh, outside air through the heater core; the air is heated and sent on to the interior of the truck. For Toyota Pick-ups/Land Cruiser/4Runner 1989-1996 check this reference repair guide...
Heater Core - REMOVAL & INSTALLATION
(see Figure 1)
  1. Drain the cooling system.
  2. Remove the heater unit assembly. Have alot of towels handy for the leakage of coolant that may spill into your interior.
  3. Remove the fasteners securing the core to the unit, remove the plates and clamps. Pull upwards to remove the core from the unit.
To install:
  1. Inspect the core fins for any blockage. Using compressed air, clean them.
  2. Install the core into the unit placing the plates and clamps into position. Tighten the core screws.
  3. Install the heater unit into the vehicle.
  4. Fill the cooling system.
Fig. 1: Exploded view of the heater unit assembly-1996 4Runner shown
Heater Unit - REMOVAL & INSTALLATION
(see Figure 1)
  1. Discharge the A/C system (if applicable), using an approved recovery/recycling machine.
  2. Remove the cooling unit (if applicable).
  3. Drain the cooling system.
CAUTION When draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Disconnect the hoses to the heater core. Tag each one so that it may be correctly reinstalled.
  2. On some models you will need to remove the glove box assembly. On others, the instrument panel and reinforcement.
  3. At the heater case under the dash, disconnect the ductwork from the case.
  4. Disconnect the heater control cables from the heater case. Lift the spring clip holding the control cable to allow the cable to be manipulated. Don't deform or crimp the cables.
  1. Disconnect the wiring harness to the blower fan.
  2. Remove the three or four bolts holding the heater case to the dash. Because the inlet tubes project through the firewall, the unit will not fall straight down. It will need to be pulled into the passenger compartment and then brought downward.
To install:
  1. Lift the case into position and carefully place the inlet and outlet pipes through the firewall. Install the retaining bolts holding the case to the dash.
  2. Connect the wiring harness to the blower fan.
  3. Connect the control cables to their linkages. Each must be adjusted so that the motion of the dashboard lever causes the correct corresponding motion in the air door. Both the control lever and the door must reach maximum travel at the same time if full function is to be achieved.
    1. Set the dashboard control to FRESH. Lift the adjustment clip and adjust the air inlet cable towards the heater unit until the linkage is at its maximum travel on Pick-Up and 4Runner. For Land Cruiser, adjust the cable away from the case. Release the adjustment clip.
    2. Set the dashboard control to VENT (Pick-Up) or DEF (4Runner and Land Cruiser). Lift the adjustment clip and adjust the air flow control cable towards the heater unit until the linkage is at its maximum travel. Release the adjustment clip.
    3. Set the temperature control to COOL. Lift the adjustment clip and adjust the air mix control damper control cable away from the heater case until the linkage is at its maximum travel on . For Land Cruiser, adjust the cable towards the case.
  4. Connect or reinstall the ductwork. Make certain each tube is firmly and completely fitted on its port. A light spray of glass cleaner serves as a good lubricant; don't use too much.
  5. Install the glove box and/or instrument panel assembly.
  6. Connect the heater hoses. Use new clamps.
  7. Install the cooling unit (if equipped).
  8. Refill the coolant, then charge the A/C system (if equipped).
Hope this help (remember comment and rated this).
Aug 02, 2010 | 1995 Toyota 4Runner
Up and down rpms . think the air vane is out of adjustment.have taken apart carburetor ,new float,needle valve and gaskets. cleaned gas screen.air filter. spring on air vane maynot be in correct postion on...
This is almost certainly due to lean mixture. If your carb is adjustable, back out the high-speed mixture screw 180 degrees.
If there is no adjustment, then either the main jet is still partially blocked, or the carb has internal corrosion (in which case, you will need a new carb - it's not fixable).
May 09, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My driver side ac blows cold, passenger side blows warm. whats the problem? 2004 ram 1500 reg cab.
A shutter is out of position, May be able to adjust under passenger dash. Move the controls to spot your target and then sync the contrpol with the shutter position, Good Luc,Ned
Sep 25, 2009 | 2005 Dodge Ram 1500
My airconditioner will only blow on the floor, i can turn the knob and it wont change.
If this is a wall or window unit, the plastic vanes on the front direct the air flow. If there is a knob to change the AIRFLOW (not the temperature) direction from "down" to "front" or some such, try removing the front panel and see if the control knob has come loose, or see if there is some kind of linkage that has come loose or is broken. Replace broken parts as needed, or fix them if you are able. If this has helped, please rate it accordingly. Good luck.
Jul 15, 2009 | Heating & Cooling
Mercedes w202 heater control unit not responding
there is a vacuum hose off that controls the vents
Mar 03, 2009 | 1995 Mercedes-Benz C-Class
Heater blower does not come out vents
Check your vacuum lines under the hood and particularly the vacuum reservoir which is a canister that supplies a reserve on vacuum to bridge the times the engine is pulling hard. These often have plastic nipples with pushed-on hoses that can snap off.
The directional control of air flow is most often accomplished with vacuum 'motors' that move vanes to change direction.
Sep 21, 2008 | 1996 GMC Savana
Direction of vane changes
Push the reset button of your remote control and try. If it wont work try to "off" and "on" the circuit breaker to reset the unit and try the remote control.
Dec 31, 2007 | Mitsubishi MS12TN Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
1,623 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
