Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite dryer
My husband is trying to help our friends out fixing their dryer. He usually has no problem, but this one is troubling.
The dryer only runs when you push the button in, when you release the buttton, the dryer stops.
He replaced the board on it, there was obvious burn marks on a few resistors. Then the owner went online got some info and ordered a thermal fuse. When they tested the fuse, it was okay, so they did not replace it.
ANY IDEAS?
    Genius:
  • 1,028 Answers
Possible interface bd(front controls)there is a lot of electronics on the back side the relay bd on top left receives most of it's commands from front controls if your husband knows how to ck things pull bottom panel off there is a tech sheet on backside..may even ck thermistor on blower housing for correct readings
Posted on Jul 30, 2008
I started the test cycle to make sure it works properly and in the middle of the test a code of D80 appears and a little smoke witch is not good. Does anyone know what this code means?
Digital control washers and dryers usually have a list of common trouble codes listed in the owners manual under, "trouble codes". Unfortunately, mostly simple codes are listed. My guess would be to check the thermister, & thermal protection fuse but you can get model specific advice in the trouble shooting section at repairclinic.com. Good luck. Try this link: http://www.repairclinic.com/RepairHelp/Appliance-Repair-Help-Lawn-Mower-Repair-Help-Small-Engine-Repair-Help
Sep 04, 2015 | Dryers
Tip
Hidden appliance information
Most of us have owned appliances that have malfunctioned or stopped working all together. If you have a basic knowledge of wiring diagrams and decent mechanical skills, and would like to do you own repair instead of paying someone a fortune to fix it, keep in mind that most major appliances have a wiring diagram tucked away somewhere within the appliance - usually folded up and attached under one of the panels. Also, if you know the brand and model number / serial number, you can usually find wiring diagrams, parts lists/descriptions and exploded views on the internet. This has helped me to trouble shoot and repair many appliances of my own and of friends.
on Apr 25, 2010 | Dryers
The dryer just makes a buzzing noise like it wants to start but just doesnt start. After I keep pressing the button it stops trying to start. Someone told me it's probably the belt. If so, is it an easy...
If you get a friend to help, try opening the door and with one hand push in the door switch, with the other hand, turn the drum clockwise while your friend pushes the start button. If it runs, you have a bad start winding in the motor or the centrifugal start switch is stuck in the run position. either way, you need a new motor:o(
Mar 24, 2011 | Dryers
My Kenmore Dryer Model # 96551220 does not run. Heating coil is fine.
When u say it does'nt run do u mean it doesn't spin??? if so ur belt is probably broken..about a $10.00 part an easy fix with a handy friend...if u mean it does'nt heat then it could be a thermal switch if it not the element....the switch is pretty cheap also and is located behind the panel in the back of the dryer...is usually white and an easy replacement as well...
Apr 05, 2010 | Kenmore Dryers
Dryer wont start on my roper dryer. Timer is working but wont start
Check for a blown thermal fuse. It's about an inch long and is located inside the rear of the dryer usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Dryers
Dryer makes like small melted black spots on metal buttons
those two stips are the moisture sensors. clean them so the shine again and try another load. Good Luck
Feb 27, 2009 | Kenmore Dryers
Can't remove bolts to mount running boards
Do u or any friends have an air compressor? If u can borrow an impact gun the bolts will come right off. I've had an air compressor for years, purchased an impact driver, can't believe how easy it removes bolts I can't budge. U may be able to rent a portable compressor and impact gun. Hope this helps, good luck, and let me know how it comes out.
Dec 28, 2008 | 2007 Ford Ranger FX4 Off-Road
My dryer doesn't heat up
I had the same problem. I called the repair man and my heating elements were broken, I had them replaced and now my dryer works fine. For me getting it repaired was cheaper then buying a new one. Your repair man should give you a free estimate on the cost
Dec 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer won't spin
low voltage to the motor or a bad motor
Dec 03, 2008 | Dryers
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Jul 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
