Question about Dell E173FP 17" LCD Monitor
My dell flat panel monitor wont come on
I have had my Dell E197FP for two years without a hitch. Today I turned on my computer and it came on as always. Suddenly, it turned off and came back on. It did it a second time and now I cannot get it to turn on. The light switch is off and would not turn on. I checked the connection at the back of the computer and it's ok. Also checked the outlet and it is also ok.
  • itsjustaride Jul 30, 2008
    I'm facing a similar problem.
    Except I don't think the turning off/on came into play here.
    It was on, and then suddenly it was off. And no I cannot detect any sounds coming from the monitor, no lights, no power, nothing.
    Have checked power cables and tried on different machines no no avail.
    Problem Solver:
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Cause of power goingoff: There is a bad 1000uF, 16V capon the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35Vcap for $2. This will work.
Why did the cap gobad? The cap is too close to a heatsink and over heated.
What does this capdo? This cap sends a signal to an ICwhich keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage isapplied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor:These monitors are difficult to open.
The two plastic pieces snap together and must be pried apartwith a flat screw driver.
After removing the stand, you need to insert a flat screwdriver at the bottom of the screen where two slots are located. Then work the screwdriver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuitboard.
Unplug the monitor cords from the driver board and removethe screen.
Unscrew the mounting screws from the power supply board andremove.
You will need to pinch the plastic support in the middle ofthe board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will beon the side of the cap. It will be bulged up on the top. You will see burnmarks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + ofthe cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from theheat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
  • 558 Answers
Blown capacitors inside the monitor on the board/s replace them and you should be good. will requiresoldering skill.
Posted on Jul 31, 2008
I am using a new Dell 3100 USB dock with two (2) Dell E197FP monitors. I can not get the monitors to change resolution and they are grayed out on 640x480. What do I need to do to get them to change?
I imagine you have just "plug-n-play" the monitors? You need to install the monitor drivers in to your computer from the driver listed on the Dell site and compatible with your operating system. This should clear the grayed out for you.
Apr 24, 2015 | Dell Computers & Internet
The monitor wont come on.i noticed the power button has been pushed inside the monitor and i need to know if i can disassemble it to get i tout without hurting the monitor
The E177fp and E197fp are identical units other than the size of the display panel. Here is a link to a repair guide for the E177fp that has videos showing how to open the unit. It should help you get your open.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-e177fpf-lcd-monitor-with-power-issues/
Nov 07, 2012 | Dell E197FP 19 inch Flat Panel LCD Monitor
Does a Dell E197fp monitor have built in speakers
Not in the monitor, there is a sound bar that attaches to the bottom of the screen that is optional that added speakers to that model.
Sep 24, 2012 | Dell E197FP LCD Monitor
My LCD Dell Flat Screen Monitor has a blue
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 12, 2010 | Dell E197FP LCD Monitor
Dell 1702FP 17" Blank Screen Problem
Try it on another computer, if it works the video card moght be dead.
Jul 11, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Monitor lights but no picture when i press the on button backlight comes on nothing else
Check the cable from AD board to TFT panel.. If not replace the AD board..
Jul 08, 2009 | Dell E197FP LCD Monitor
Dell E197FP - Screen turns off and on constantly
Check the video connector to make sure it is clean and tight. Look closely for broken or bent pins by GENTLY rubbing your finger across the pins.
Otherwise, it sounds like the monitor screen is failing or has faulty wiring or components inside.
Sep 03, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
320 people viewed this question
Alun Cox
