You can use MS Paint to scan documents by going to start, all programs, accessories, Paint. Click file and from scanner or camera. Then you can save it as a jpg or any other file type.
Down load the software for your windows 32 or 64 bit here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1138373&
You need the full package to use the scanner.
To scan a picture or document, follow these steps:
Step one: Load the item to scan
You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
Step two: Scan the item
After the scan completes, it goes to the destination that you specified in the settings.
which software to scan ? - hpweb_1-2_plus.gifads/images/hpweb_1-2_plus.gif" alt="hpweb_which software to scan ? - hpweb_1-2_minus.gif="h_mi" />
Using the scan button on your printer
HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then which software to scan ? - c01940398.gifeasily set up the scan button on your printer.
Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer.
To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
A screen displays to prompt for scan settings.
If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
