Question about Minolta DiALTA Di181 Printer
Minolta dialta di181 c1300 error
I just got this copier and when I press print I get error C1300 can you help?
Thank you,
Bill
  • 1 more comment
  • Anonymous Feb 07, 2009
    error c1300
  • cyberangel Mar 26, 2009
    i have the same problem can u help me
  • i-m-t Nov 09, 2009
    error c1300
  • 145 Answers
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Posted on Oct 21, 2008
    New Friend:
Mesin photo copi saya membayang/berbayang hitam typenya minolta dialta di2510 bagaimana solusinya. daffa mojokerto
Posted on Nov 20, 2013
C1300 error code Minolta Di250F
Print Head failure. The print head is what has the copier LASER inside of it. Check the connection between the print head and Master board. Replace the print head fist then board, if you can find either one. The Di250F is a legacy Minolta machine now konicaminolta.
Jan 07, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Malfunction detected call for service c1300
Print Head (Where the LASER is) is bad or the circuit board that controls it. Check the connections between them. Print head first if I had a say.
Sep 27, 2013 | Minolta DiALTA Di250f All-In-One Laser...
Error code c1300
Print head failure the print head houses the LASER. Chk the connection between print head control board. replace print head first if then not that control board. CHECK all connections on the control board first also bent PIN! pull each connector one at time
Apr 05, 2013 | Minolta Office Equipment & Supplies
C1300 code on dialta Di251
print head failure. print head houses the LASER. Check the connection between the LASER (Print head and the control board. CHECK FOR BENT PIN
Nov 12, 2012 | Minolta Office Equipment & Supplies
C1300
C1300 indicates a laser mirror motor failure. Given the age of the machine this is going to be expensive to repair as parts are becoming harder to find. The part that has failed is your machine is a spinning mirror that the laser bouces off of and is responsible for "writing" the image onto the drum. The motors freeze up over time and when the motor does not rotate at all or at the proper speed the C1300 code is generated. I would estimate you are looking at something in the area of $400 to $500 to repair the machine. It may be time to look at a replacement machine.
Sorry for the bad news.
Good Luck and Thank You for using Fixya.
WheatlandServices
Oct 19, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Error code c 1300 How can I fix this????
The c1300 error means that the Laser Printer needs a new Laser Unit. Unfortunately, it will have to be serviced/replaced.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Di181 Code C1300 What does this mean? How do I
The PRINT HEAD has failed that is the LASER UNIT in the machine, need a new one
Aug 03, 2009 | Konica Minolta Office Equipment & Supplies
DI181 ERROR C1300
The motor in side the print head error the print head houses a motor which scans the LASER across the drum, can't get just a motor you get the entire print head try this site if they still have them you have a legacy Minolta machine now Konica Minolta. Open close the front door to reset.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 25, 2009 | Minolta DiALTA Di181 Printer
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Minolta Di181 C1300 Service call
my copier is minolta di 181 it shows c1300 .how can i repair this problme? thank you.
Dec 17, 2008 | Minolta DiALTA Di181 Printer
1,181 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
